Is camshaft tower leaking still an issue on the ‘21’s
Discussion in '2.5 Gen Tundras (2014-2021)' started by Xcumminsguy, Oct 20, 2023.
  1. Oct 20, 2023 at 8:12 AM
    Xcumminsguy
    Xcumminsguy [OP] New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    I’ve gone through a bunch of pages on the sticky thread on the cam shaft towers leaking, but don’t recall anyone mentioning the ‘21. Was it determined that the black gasket material is the cure to the lack of enough grey gasket sealer applied at the factory and is leaking in those areas resolved for the later 5.7’s? Thanks guys.
  2. Oct 20, 2023 at 8:15 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I have always thought that it is an issue Toyota never addressed on the 3UR-FE.
    In the vast majority of cases, it doesn't even seep enough to change the reading on your dipstick between oil changes. For very few people, it seeps enough that they can smell a bit of burnt oil.
  3. Oct 20, 2023 at 8:52 AM
    Xcumminsguy
    NY
    Seems I could live with a bit of seepage. Thanks.
  4. Oct 20, 2023 at 8:58 AM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    i have 183k on the clock and it's still seeping with no noticeable oil loss, burnt oil smell, or stains on the ground.
  5. Oct 20, 2023 at 10:14 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    When did yours start seeping?
  6. Oct 21, 2023 at 10:04 PM
    DoublePro
    DoublePro New Member
    My 2008 started at 120k, truck currently has 225k
    Jaypown likes this.
  7. Oct 22, 2023 at 4:31 AM
    Retired...finally
    Does ambient temperature swings have anything to do with the oil leak? Are southern trucks seeing this as well as northern?
  8. Oct 22, 2023 at 5:02 AM
    2mchfun
    Another reason to use 5w-30:stirthepot:
    vtl, Silver17, Joe333x and 3 others like this.
  9. Oct 22, 2023 at 8:23 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    But is Kirkland as good as Mobil 1?
  10. Oct 22, 2023 at 8:36 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    You stop that right Meow.
  11. Oct 22, 2023 at 9:03 AM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Yes, some 2021 owners have posted the leak in the sticky.
  12. Oct 22, 2023 at 11:10 AM
    Xcumminsguy
    NY
    Ty Lug Nut.
  13. Oct 22, 2023 at 6:55 PM
    2mchfun
    Not gonna debate that much as I have bigger fish to fry. I'll just say brand doesn't matter nearly as much as the frequency of changes, the running duration periods, the rpms during those running cycles, and the proper operation of the PCV system. Lots of people overlook PCV system maintenance which leads to highly contaminated motor oil and premature engine wear in any vehicle.
    Terndrerrr likes this.
  14. Oct 22, 2023 at 7:05 PM
    Terndrerrr
    Music City
    6UR-FE
    I love Kirkland. I buy a bunch when it's on sale. I can do 5k oil changes with Kirkland cheaper than I was doing 10k changes with Amsoil. :benchpress:
    2mchfun likes this.
  15. Oct 22, 2023 at 7:21 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    And so the derailing begins
  16. Oct 22, 2023 at 7:45 PM
    Terndrerrr
    Music City
    6UR-FE
    What’s the biggest tire you can run with no lift if you have the cam tower seepage?
  17. Oct 22, 2023 at 8:07 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    FOR THE LOVE OF GOD!!!
    Gene_in_FL, BTBAKER and Terndrerrr like this.
  18. Oct 23, 2023 at 5:15 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    It depends on your payload and if you have WDH on your 32' Toy Hauler.
  19. Oct 23, 2023 at 5:21 AM
    Retired...finally
    I have it on good authority that only Tundras with towhooks can develop this oil leak.
    Ebrperk and Jaypown[QUOTED] like this.
  20. Oct 23, 2023 at 7:40 AM
    Terndrerrr
    Music City
    6UR-FE
    I heard if your cam towers seep a lot, then it reduces your curb weight and you can run a sliding 5th wheel hitch in your crewmax.
  21. Oct 23, 2023 at 7:47 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Well, that, of course, depends on how much of your 38 gallon tank you can use before it shows empty on the gas gauge.
    Jaypown and Terndrerrr[QUOTED] like this.
  22. Oct 23, 2023 at 9:04 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    is that with or without chrome? what if you debadge? :monocle:
    Saltyhero13 and Reddawg1100 like this.
  23. Oct 23, 2023 at 9:07 AM
    40man
    40man New Member
    Stickyleaks.
    Retired...finally likes this.
  24. Oct 23, 2023 at 9:11 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Weird, because I heard the seeping makes it easier to run 37”+ tires because it lubricates the wheel well and minimizes rubbing.
    Saltyhero13 likes this.
  25. Oct 23, 2023 at 9:41 AM
    Retired...finally
    I never gave that much thought but I was aware the oil leaks were the result of Toyota's skunkworks type focus group's work to prevent future frame rust recalls. It was either that or an attempt to attract Harley Davidson owners.
    Reddawg1100 likes this.
  26. Oct 23, 2023 at 9:50 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Lot bigger, because the leaking oil will lube the rubber and it won't squeak touching the liners.
  27. Oct 23, 2023 at 9:51 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    There was an opinion that the sealant is compromised with the oil turning acidic. Trucks with short OCI don't see that problem at all or see it only much later in life.
  28. Oct 23, 2023 at 10:50 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    This poor thread :rofl: It started so good then fell off the tracks
  29. Oct 23, 2023 at 12:05 PM
    Xcumminsguy
    NY
    It happens…
  30. Oct 23, 2023 at 12:38 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Stir that pot
