2023 Tundra Pro lift
Discussion in '3rd Gen Tundras (2022+)' started by metalmaniac, Oct 21, 2023.
  1. Oct 21, 2023 at 3:05 PM
    metalmaniac
    metalmaniac [OP] New Member
    Jay
    2018 Crewmax limited
    Been a long time since I posted. So I recently acquired a 23 Tundra Pro. I would like to lift it more than the standard Wescott kit. Something like the pro comp 5 inch lift is what I desire. Every kit specifically states non applicable for the 22/23 pro
    My question would be, what would need to be swapped out to make it possible?
  2. Oct 21, 2023 at 3:44 PM
    metalmaniac
    Jay
    No, it uses rear coil spacers. It's actually listed as a 6 inch lift.
    6″ Lift Kit with Shock Extensions and Upper Control Arms – K5103EU
    Part # EXPK5103EU
  3. Oct 21, 2023 at 3:51 PM
    18" TRD Off Road Wheels
    You'd have a better shot asking pro comp why it won't work. They should be able to answer pretty easily, and then you'll know exactly what problem you are trying to solve.
  4. Oct 21, 2023 at 4:22 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Please post what they tell you
  5. Oct 21, 2023 at 7:51 PM
    metalmaniac
    Jay
    I plan on calling them on Monday. I was hoping someone on here had already lifted one and it had been discussed. I will post the findings from pro comp.
  6. Oct 21, 2023 at 8:22 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I’m pretty sure cause the pro comes with a 1.1” lift already.
    The 6” lift will lift the front 6” and a matching rear lift to level it out.
    I’m positive you could use the 6” lift with the pro suspension granted you use the base kit and you will get 7.1” lift total in the front which will leave you with the “Cali Lean” unless you go rear springs to match the 7.1” lift.
    If you opt for a full 6” lift that replaces front fox shocks, then it will be a straight forward 6” lift.
