Oil pressure (and voltage)
Discussion in '1st Gen Tundras (2000-2006)' started by drapp, Oct 21, 2023.
  1. Oct 21, 2023 at 11:55 AM
    drapp
    drapp [OP] New Member
    Virginia
    2005 AC Tundra V8 4WD
    2005 AC 4x4, 174k miles. I bought used in 2021. Runs great! Except when it doesn't! I love this truck.
    I have 2 questions ...
    When I run it after it's sit a week or two, battery voltage reads a bit higher than "center" for 20-30 minutes. I assume that means it's charging, which must mean there's some kind of parasite draw while it's sitting. Does that seem right?
    More important, the oil pressure almost always reads 1/4 on the gauge. When I first bought it I think it read "center" most of the time. Is it trying to tell me something?
    Thanks guys
  2. Oct 21, 2023 at 12:02 PM
    Some parasitic draw is normal. The more aftermarket crap you have, the more parasitic draw you'll see. My '06 gauge naturally fluctuates right around where you are. That's actually normal.
    For the oil pressure gauge, are you low on oil? Did you change it recently, and maybe use a lighter weight, or switch to full synthectic vs. dino? It could be your sender is taking a took a shit. There's a TSB on that for earlier years, and a new part number for the sender, you may want to consider replacing? (my gauges while warm, should be same across '05-'06, are below)
  3. Oct 21, 2023 at 12:43 PM
    atomicnugget
    atomicnugget My bones hurt
    New Jersey
    2001 V8 Limited Access Cab 4x4 w. TRD package
    01 here but my pressure rises to around yours or a bit higher when waking her up, about constant halfway when just cruising, dips to around a quarter to half when neighborhood cruising, and straight up scary level low when idle/parked after warming up.
    Yet this is supposed perfectly normal at least for my year per my manual lol so I’d consider your gauge with a grain of salt
    Aerindel likes this.
  4. Oct 21, 2023 at 2:21 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    The biggest reason your battery is showing a charge after starting is because the battery just took a hit to start the engine. I measured the parasitic draw on my 2001 at 20 mA I believe, from memory, but it was in spec. I do remember that much.
  5. Oct 21, 2023 at 2:48 PM
    atomicnugget
    New Jersey
    Sorry I confused shiftys pic for yours. If your gauge stays at quarter even after pushing it hard on the highway, I’d check out the places he suggested. Even tho the gauge levels are fucked in terms of what’s considered normal, at the very least I’ve always had it rise to about half or slightly the more you push the engine. If yours stays at that level constantly, I’d take it as a sign something iffy
  6. Oct 21, 2023 at 5:20 PM
    Mr Badwrench
    Mr Badwrench New Member
    The gauges on the gen 1s give you a cartoon depiction of what is actually going on. They get worse with time too. I would bet you are running fine.
  7. Oct 21, 2023 at 5:38 PM
    It's so much better on the later years. All needles sit in the middle when all is normal.
    Mr Badwrench[QUOTED] likes this.
  8. Oct 21, 2023 at 6:18 PM
    Mr Badwrench
    The new ones are so consistent sometimes that I am concerned that they are not even correct, especially after owning the older ones. :rofl: I am thinking "why is my dashboard not giving me anxiety?"
    shifty`[QUOTED] likes this.
