Newbie with 06 Sr5 DblCab - Running boards needed for Short Wife
Discussion in '1st Gen Tundras (2000-2006)' started by Trueno, Oct 19, 2023.
  1. Oct 19, 2023 at 3:22 PM
    Trueno
    Trueno [OP] New Member
    Will
    2006 Sr5 Dbl Cab
    Tomorrow I'm buying a one-owner 2006 DC with 250K miles. Interior, exterior and frame look good according to pictures. Tomorrow I'll be seeing it for the first time and will most likely buy it.
    The owner has been forthcoming about timing belt (and water pump) needed to be done, and I know it is one of the first things that need to be done. I'm going to drive it to my independent mechanic right after I bring it from Pennsylvania. What other things should I have it done? checked? I always replace the Engine Oil/Filter. Should the Transmission Fluid be replaced as well?
    Lastly, please point me to a thread or a corner of the forum where I may find information on where to buy a set of running boards. Wifey is 4'8" and our little kids can use the help climbing onto this rig.
    The Black Mamba likes this.
  2. Oct 19, 2023 at 4:09 PM
    Welcome from NY.
    Trueno[OP] likes this.
  3. Oct 19, 2023 at 4:22 PM
    daveeasa
  4. Oct 19, 2023 at 5:25 PM
    bfunke
    bfunke Tundra Curmudgeon
  5. Oct 19, 2023 at 5:50 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  6. Oct 21, 2023 at 8:39 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    OEM running boards for me - I never much liked the look or clearance they stole from me - but my wife and kids needed em too. Once I got over the fact they're on there I use them 90% of the time. You could probably just start your search for some OEM take off junk now - the mounting of them is superior to the nerf type tube junk.
    + it prolongs that outboard ass cushion wear that every )(#@&%@# toyota suffers from eventually.
  7. Oct 21, 2023 at 9:31 AM
    I always open the door for my wife and assist her inside. If my hand is placed on her ass...so be it. It's all about getting her safely inside.
  8. Oct 21, 2023 at 9:47 AM
    daveeasa
    If I tried that move I suspect I’d get a beating I wouldn’t forget. Hah.
