    1 vote(s)
    3.3%
  2. Yes - roll/swipe on
    27 vote(s)
    90.0%
  3. Yes - areosol
    2 vote(s)
    6.7%
  1. Oct 21, 2023 at 6:10 AM
  2. Oct 21, 2023 at 6:44 AM
    Blue Thunder
    Washington
    WaDaFuk!? That’s some next level cult shit
  3. Oct 21, 2023 at 7:05 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Like, a rabbit cult where they all committed suicide so the UFO could collect their souls?
  4. Oct 21, 2023 at 7:06 AM
    Outbound
    Aaron
    Northern Alberta
    Second question:
    Why?
    GODZILLA and T-Rex266 like this.
  5. Oct 21, 2023 at 7:12 AM
    Blue Thunder
    Washington
    My Blackstone sits on a stainless steel cart that I roll in/out of the garage when I want to use it.
  6. Oct 21, 2023 at 7:14 AM
    Blue Thunder
    Washington
    Exactly like that. But maybe they killed a bunch of rabbits to satisfy some God so they don't blow up the Earth.
  7. Oct 21, 2023 at 7:18 AM
    Outbound
    Aaron
    Northern Alberta
    Third question:
    No backyard?
  8. Oct 21, 2023 at 7:19 AM
    Outbound
    Aaron
    Northern Alberta
    I'm thinking it was a bait pile to attract a chupacabra
  9. Oct 21, 2023 at 7:27 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    That's stupid. Mass suicide makes way more sense.
  10. Oct 21, 2023 at 7:33 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Also, consider the source.
    It may have been a hallucination. Or a made up story for attention.
  11. Oct 21, 2023 at 7:44 AM
    Blue Thunder
    Washington
    Yes, I have a backyard.
  12. Oct 21, 2023 at 8:00 AM
    Outbound
    Aaron
    Northern Alberta
    Fourth question:
    Why not put the the Blackstone in the backyard?
    I'm asking because I'm honestly curious. I had a neighbour awhile back who had a nice backyard with a deck and door from his kitchen leading to it but parked his grill in the garage. He'd wheel it out to do his grilling in the driveway. He'd have to bring his food through the house and through the garage to the grill. It made no sense to me. He wasn't hosting block parties or inviting neighbors to joing him either, it was just him and his wife and some frozen burger patties.
  13. Oct 21, 2023 at 8:03 AM
    During winter or rain, I’ve rolled my Blackstone into the garage to cook
    GODZILLA and Blue Thunder like this.
  14. Oct 21, 2023 at 8:10 AM
    Outbound
    Aaron
    Northern Alberta
    That kind of makes sense, I suppose
    During winter I shovel the snow off my deck to get to my grill and in the rain I get wet. It'd be a huge production to get my grill from my deck to the garage, involving disassembing it and carrying down the stairs to ground level.
  15. Oct 21, 2023 at 8:30 AM
    Blue Thunder
    Washington
    NWPirate, GODZILLA, T-Rex266 and 2 others like this.
  16. Oct 21, 2023 at 8:45 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    During a substantial part of the year, it’s wet here. Unless the back porch/patio is covered, grills deteriorate quickly and grilling generally becomes unenjoyable.
  17. Oct 21, 2023 at 8:57 AM
  18. Oct 21, 2023 at 9:35 AM
    Blue Thunder
    Washington
    The grill on the BS isn’t stainless so I don’t want to leave it out in the elements. They turn into rust buckets pretty quickly around here with all the rain and moisture. Plus I have a gas grill already on my deck, so no room for a second grill. The garage is a longer walk from the kitchen, but the best solution overall.
  19. Oct 21, 2023 at 9:58 AM
    Outbound
    Aaron
    Northern Alberta
    Fair points. Carry on sir!
  20. Oct 21, 2023 at 10:30 AM
    Blue Thunder
    Washington
    :hattip:
  21. Oct 21, 2023 at 10:54 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Resident(s) wiring masters free today to help a fella out with wiring up his ditch lights to work with high beams? I swear when I try to do electronics and wiring my IQ goes to single digits.....
  22. Oct 21, 2023 at 11:01 AM
    RainMan_PNW
    Casey
    Clark County, WA
    semi available.
    do you have wiring diagrams for the high beams? I'm not intimately familiar with with tacos
  23. Oct 21, 2023 at 11:06 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    So, I already know which fuse to use the fuse tap on, I'm mainly confused on what goes into the fuse tap. I have this pre-made harness. If I just want to do the basic come on every time high beams are on, I need to use that fuse tap and go into the blue wire and that's it right? Because the black wire is the negative (The one that goes to the brass post on the rocker switch) and then the blue one is the positive right? And then the white is just like positive but a different color lol!? So I can just unplug the extra length of wire that goes to the rocker switch and then cut the plastic connector off and then put the fuse tap into the blue and I'm good to go right?
    Blue Thunder and T-Rex266 like this.
  24. Oct 21, 2023 at 11:33 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Just checked! It is indeed the blue wire lol
  25. Oct 21, 2023 at 11:35 AM
    RainMan_PNW
    Casey
    Clark County, WA
    that's a great close-up, but I'm strugling to understand what I'm looking at.
    What is the white/clear socket?
    Did this thing come with a wiring diagram at all?
    Have you run a continuity check across the rocker switch? What kind of switch is it (basic on-off, or on/off/on two-position, or something else)?
  26. Oct 21, 2023 at 12:33 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I got it wired up, sorry for bothering you but I appreciate your willingness to help :)
    Blue Thunder, T-Rex266 and GODZILLA like this.
  27. Oct 21, 2023 at 12:35 PM
    RainMan_PNW
    Casey
    Clark County, WA
    no worries
    glad you got it working!
  28. Oct 21, 2023 at 12:38 PM
    18" TRD Off Road Wheels
    Yeah, I thought it was a muddy snow pile, but our snow hasn't stuck yet.
  29. Oct 21, 2023 at 1:44 PM
    Azblue
    The Dirty T ( ^_^)_且
    Just got back from a quick trip to the grocery store. I don't think I've ever seen a keg of whiskey before.
  30. Oct 21, 2023 at 2:11 PM
    But does it work? :laugh:
    And did you get it? If not, what did you end up with?
