Auto Door Unlock When in Park
Discussion in '3rd Gen Tundras (2022+)' started by OCzipPAC, Oct 18, 2023.
  1. Oct 18, 2023 at 8:09 PM
    OCzipPAC
    OCzipPAC [OP] New Member
    How do you disable the Automatic Door Unlock feature when you put the truck in park?
  2. Oct 18, 2023 at 8:13 PM
    18" TRD Off Road Wheels
    I don't have a 3rd gen Tundra, but I had a 2.5 gen and currently a Tacoma, so if it is anything like those it should be an option in your head unit. Vehicle usually has to be running in park, and there should be an option in settings for vehicle customization and you can set the lock/unlock behavior along with light behavior. The new Tundras might have moved it to the dash options, but it should be in one of the two.
  3. Oct 19, 2023 at 7:04 AM
    nodak67
    nodak67 New Member
    JR
    its in the manual for vehicle settings.
  4. Oct 19, 2023 at 10:09 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
    Its in the infotainment system settings under vehicle settings, but the menu only appears when the ignition is on (double press start button), not in accessory.
