Noise under truck once you hit 20km/hr
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra Sask, Oct 18, 2023.
  1. Oct 18, 2023 at 4:09 PM
    Tundra Sask
    Tundra Sask [OP] New Member
    2014 Tundra SR5 Crewmax
    I'm fairly new to my 14 Tundra (March of 2023) and was wondering what the noise is under the truck once you hit 20km/hr. It only happens after a startup and when you just pass 20km/hr, it sounds like something is engaging or something. Was just curious what it was, I'm guessing it's normal, but just wanted to check, thanks!
    cmiles97 likes this.
  2. Oct 18, 2023 at 4:13 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That sounds like the ABS self check, totally normal.
  3. Oct 18, 2023 at 4:18 PM
    Figgy
    Figgy New Member
    Rene
    Vancouver, BC
    2018 White CM TRD Off Road
    ABS check (click). Usually happens after driving forward for about 10-15ft or so...
    Tundra Sask[OP] and cmiles97 like this.
  4. Oct 18, 2023 at 4:19 PM
    Tundra Sask
    awesome, thanks! appreciate it!
  5. Oct 19, 2023 at 7:37 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Thanks OP. I had the same question.
    I figured it must be normal as it does it every time and the truck runs great.
    It only does it after starting up and leaving.
    Tundra Sask[OP] likes this.
  6. Oct 19, 2023 at 7:44 AM
    cmiles97
    cmiles97 New Member
    XP package
