New Member from Texas
Discussion in '2.5 Gen Tundras (2014-2021)' started by MowoG67, Oct 18, 2023.
  1. Oct 18, 2023 at 8:24 AM
    MowoG67
    MowoG67 [OP] New Member
    Tom
    2020 Tundra SR5
    Catalytic Converter Anti Theft
    I have a 2021 SR5 and recently noticed that the toggle between high beams to low beams does not work in the Auto position.
    Anyone have any ideas why this might occur?
    Thanks in advance.
  2. Oct 18, 2023 at 10:03 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    When you have the switch set to auto you cannot control them, its automatic. If you turn off automatic then you can operate them independently.
    Nyy020 likes this.
  3. Oct 18, 2023 at 10:34 AM
    MowoG67
    Tom
    2020 Tundra SR5
    Joe,
    Yes I know that part, but when a car approaches the lights do not dim, like they use to when it was new.
    what’s next???
  4. Oct 18, 2023 at 12:11 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    So the auto feature is just not working?
  5. Oct 18, 2023 at 12:21 PM
    MowoG67
    Tom
    2020 Tundra SR5
    To All,
    Yes the auto feature works for turning the lights on, but the dimming portion of the auto part is not working
    when the bright lights are on. When the switch is set to Auto and you push the turn signal arm forward, the bright lights come in, but when a car approaches the lights should dim back to normal, but they don’t as I have to do it manually.
    They should dim automatically as that is what it is supposed to do, but mine does not. It used to work until I drove out to Lubbock TX.
  6. Oct 18, 2023 at 12:24 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Dirty sensor? Whatever controls the auto high beam isn't seeing the oncoming traffic for some reason.
  7. Oct 18, 2023 at 12:25 PM
    MowoG67
    Tom
    2020 Tundra SR5
    Can you tell me where that sensor is at?
    Thanks
  8. Oct 18, 2023 at 12:40 PM
    Joe333x
    Joe333x Member
    Boston
    The sensor is in front of the rearview mirror
  9. Oct 18, 2023 at 12:42 PM
    MowoG67
    Tom
    2020 Tundra SR5
    Ok Thanks for the info and I will look at it later today.
  10. Oct 18, 2023 at 12:47 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah hard to believe the sensor is bad already. Could have debris blocking it causing the feature to not work.
  11. Oct 18, 2023 at 12:55 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Apart from having the headlight switch in auto, do you have the automatic high beam switch turned on in the lower left side of the dash?
    Terndrerrr likes this.
  12. Oct 18, 2023 at 1:43 PM
    MowoG67
    Tom
    2020 Tundra SR5
    Mr. Tilley,
    When I get back in my truck later today will look for it on the lower left side of the dash, but I don’t remember seeing anything like that before.
  13. Oct 18, 2023 at 2:36 PM
    TILLY
    Massachusetts
    Should look like this switch in the middle.
    Joe333x likes this.
  14. Oct 18, 2023 at 4:07 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Also check for a rock peck in front of the sensor camera.
  15. Oct 18, 2023 at 4:29 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    This is exactly it. That little button needs to be pushed. The same icon will light up on your dash when it is pushed and your headlight stalk is forward (you still have to push the stalk forward to turn high beams on). The auto part is that when the truck senses oncoming traffic, they will dim automatically. It’s really works very well—much better than I thought it would.
    The “auto” setting on the stalk just means the headlights will turn on/off when the truck is turned on/off, and they will sense which mode to run (DRL vs headlight) depending on how light it is outside. If you want auto hi-beam, you have to push the button on the lower left part of the dash that @TILLY posted a pic of.
    Nyy020 and TILLY[QUOTED] like this.
  16. Oct 18, 2023 at 6:01 PM
    MowoG67
    Tom
    2020 Tundra SR5
    To All,
    Well the winner is Mr. Tilley as I looked and sure enough the button was not on. I found out after I got home that my
    lovely wife could not get the back window up when she took our grandsons for a ride and pushed all buttons to get it.
    Thank you Mr. Tilley and all the others for your help.
    Joe333x, TILLY and Terndrerrr like this.
  17. Oct 18, 2023 at 6:23 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That’s the best kind of fix. Glad you’re all set!
  18. Oct 18, 2023 at 6:45 PM
    Welcome from NY.
