Crooked leaf spring 2021 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by G0rhax, Oct 17, 2023.
  1. Oct 17, 2023 at 7:07 PM
    G0rhax
    G0rhax [OP] New Member
    IMG_0652.jpg IMG_0654.jpg Today I noticed my bottom leaf is a bit crooked in the pack. From what I’ve measured, the axle has not shifted and everything is tight. What could cause this or is it for some reason supposed to be like this? First image is the driver side that is shifted compared to the passenger side.
  2. Oct 18, 2023 at 4:42 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    It’s very common. When the truck flexes the springs actually twist. The twisting is what makes it rotate. You can take a sledge hammer and knock it back if it bothers you.
    FrenchToasty and nobodyintexas like this.
  3. Oct 18, 2023 at 4:44 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    it's common.
  4. Oct 18, 2023 at 6:50 AM
    CaptRatBoy
    CaptRatBoy New Member
    Somewhere around 2500' Western Blue Ridge, NC
    Capeable, extensively modified, 2016, Limited, 4 x4 Tundra Off Road, 3td. one
    Sometimes it's intentional. The last, or first depending on your perspective, spring in the pack is designed to act as an overload spring. Note that big ole compression washer? It's there for a reason
