Part number for drain and check plug on a AB60E trans?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by rodm1, Oct 14, 2023.
  1. Oct 14, 2023 at 6:05 AM
    rodm1
    rodm1 [OP] New Member
  2. Oct 16, 2023 at 6:25 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    These are not the correct gasket for the transmission pan plugs, but I had trouble getting mine to seal after changing fluid, and had these handy. They work perfectly, and I like them better. They’re for the engine oil pan plug.
    https://a.co/d/amW9t3c
    rodm1[OP] likes this.
  3. Oct 17, 2023 at 5:24 PM
    rodm1
    That is a grate idea I will keep that in mind if the proper ones don't seal.
