How long are LBJ good for when replaced?
Discussion in '1st Gen Tundras (2000-2006)' started by reefrash1043, Oct 17, 2023.
  1. Oct 17, 2023 at 4:12 AM
    reefrash1043
    reefrash1043 [OP] New Member
    Nashville
    2005 Limited Tundra
    Was going through my trucks service records on the Toyota website and it turns out I had the LBJ replaced under warranty in 2014. Are these good for the life of the vehicle or do I still need to be concerned about these?
    2/2014
    SSC-70B(2.6)
    SSC-70B(2.6) ~|~REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS AND CHECK & ADJUST THE FRONT END ALIGNMENT. ~|~SSC 70B ~|~PERFORMED A SSC 70B. PERFORMED A FOUR WHEEL ALIGMENT.
  2. Oct 17, 2023 at 4:27 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Just check status with tire rotations. It’s not on my maintenance list but I’m also not a true “gear head”
    GreenMachineDream and shifty` like this.
  3. Oct 17, 2023 at 4:28 AM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    You should get at least 100,000 miles from new Toyota LBJ.
  4. Oct 17, 2023 at 5:09 PM
    Trox416
    Trox416 New Member
    Western MT
    2002 SR5 Extra cab 4x4
    OEM should be good for 100k.
