Anyone else doing truck maintenance for hunting season?
Discussion in 'Guns & Hunting' started by kevine0001, Aug 21, 2023.
  1. Aug 21, 2023 at 1:10 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    Did my oil change. Had to take it to mechanic to do diff/t-case fluids. For the life of me, I could not get the rear diff fill plug to turn. Not stripped and I know I put it on to specs last time. Didn't have time to mess with it, so dropped it off at mechanics with all my fluids and a new fill plug from the dealer. Transmission was done about six months ago. Should be all ready for dirt driving for a couple months, unless I get lucky and tag out early.
    Medic343 likes this.
  2. Sep 22, 2023 at 2:01 PM
    10 ga Bob
    10 ga Bob New Member
    Bob
    2012 Regular Cab Long Bed 4X4 SR5, 2023 DC TRD 6.5 Ice Cap
    ARE Cap
    On my 2012, I had to heat the diff fill plug with a propane torch and then lock some vise grips onto it then tap the vise grips with a hammer to break it free. This was due to the salt and brine they put on the roads here in winter. Obviously had to replace the fill plug. After that, both rear wheel bearings went bad, again due to corrosion. After a $2k repair bill and $1300 for new rotors and pads again, due to corrosion I finally sold the 2012 and bought a 2023 TRD SR5 DC. Probably should have kept the 2012 with 179K miles on it because it still ran great. The E brake was also corroded so bad that it would stick if I used it. Liking the electronic E brake on the 2023.
    as far as getting ready, since the truck is new, all I did was order an ARE cap, bought and installed Wet Okole neoprene seat covers so I can wear my wet, muddy waders while driving and just ordered a Taco Tunes aluminum cat shield so some meth head won't steal my catalytic converters while I'm parked in BFE waterfowling or steelhead fishing this winter.
  3. Sep 25, 2023 at 2:45 PM
    kevine0001
    Kevin
    I always make sure my maintenance is up to date. Just happened that certain fluids were due this Aug. Must have worked, because I tagged out for archery on opening morning
    dondino likes this.
  4. Sep 25, 2023 at 3:03 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I'm ready to go just had the 07 undercoated this week with NHO, maintenance is up to date, about the only thing is the tires. They'll get me through til next spring but if I get out into a cut corn field that's really muddy ( goose hunting) I might run into some trouble.
  5. Sep 30, 2023 at 3:21 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    They can be difficult for sure. It took putting a camping torch to the front diff plug on my wife’s 200-series till it was nice and warm, and using my foot to push on a breaker bar to get it to finally break free. Congrats on your harvest
  6. Oct 17, 2023 at 4:52 PM
    Trox416
    Trox416 New Member
    Western MT
    2002 SR5 Extra cab 4x4
    All new ball joints, tie rod ends, timing belt/water pump, steering rack bushings and alignment after all that. Feeling somewhat solid about the rig this year
    kevine0001[OP] and FrenchToasty like this.
  7. Oct 17, 2023 at 4:54 PM
    Oem BJs?
  8. Oct 17, 2023 at 4:57 PM
    Trox416
    Trox416 New Member
    Western MT
    Sigh.... its a whole story, but the OEM kit I got from the dealership is for a *different* 2002 tundra than my 2002 tundra. So went with Napa premiums (which are somehow $40 more than the OEM kit) when I was down to about 3 hours before my alignment appointment and 18 hours from the start of a week long pheasant/antelope trip.
    I know, sketchy. But desperate times....
  9. Oct 17, 2023 at 4:57 PM
    Trox416
    Trox416 New Member
    Western MT
    And I should say, the UBJ's are OEM, all the trouble was with the LBJ's
  10. Oct 17, 2023 at 5:02 PM
    Trox416
    Trox416 New Member
    Western MT
    All that being said, put 2000 miles on the truck (Montana is a big state, turns out) and the hunting gods provided dad antelope.jpg obie birds.jpg
  11. Nov 26, 2024 at 7:02 PM
    Prestoman13
    Prestoman13 New Member
    Preston
    2008 crewmax SR5
    Wish I would have done my 4wd exercises a few more during the off season. Think I have a bad actuator and another hunting trip in the near future..
  12. Jan 24, 2025 at 9:50 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Not for hunting season per se but I once did a pre-emptive oil change before I went on a 1600 mile ski trip (there and back).
    kevine0001[OP] likes this.
