Need Tire Chain Recomendations
Discussion in 'Wheels & Tires' started by Fever Buck, Oct 16, 2023.
  1. Oct 16, 2023 at 12:36 PM
    Fever Buck
    Fever Buck [OP] New Member
    2024 Tundra TRD Pro
    Howdy y’all,
    Going on an elk hunt mid November out here in Colorado and need to get some chains for my tires on my Pro. Tires are 285/65R18. Anyone have any recommendations or all chains the same?
    thanks!
  2. Oct 16, 2023 at 12:47 PM
    kostic
    kostic New Member
    Konig are excellent but pricey.
    Fever Buck[OP] likes this.
  3. Oct 16, 2023 at 1:02 PM
    AdamK
    AdamK New Member
    Check out etrailer - they had (assuming they still do) very competitive pricing and a great selection of truck chains when I bought mine a couple of years ago. I got a double set of their Glacier Twisted Link and the rubber snubbers (don’t forget those if going with actual chains).
  4. Oct 16, 2023 at 1:31 PM
    Fever Buck
    2024 Tundra TRD Pro
    Thanks. I’ll check that out.
  5. Oct 16, 2023 at 1:31 PM
    Fever Buck
    2024 Tundra TRD Pro
    Thanks
  6. Oct 16, 2023 at 3:35 PM
    Swanie80
    Swanie80 New Member
    B
    2023 Tundra 1794 TRD OR
    3" Lift, 35" Tires, Fuel Rims
    I saw in the owners manual that they don't recommend chains on larger tires, or at least the TRD OF wildpeaks, due to clearance issues. Has anyone run them with larger tires, like 35's?
  7. Oct 16, 2023 at 4:12 PM
    Fever Buck
    2024 Tundra TRD Pro
    So you’re saying that even just the standard 33s they don’t recommend chains for?
  8. Oct 16, 2023 at 4:38 PM
    coTony
    Tony
    Montrose, CO
    I don't think there is a lot of room on the stock tires under there with chains at full turn and stuff, I could be wrong
  9. Oct 16, 2023 at 5:10 PM
    Swanie80
    Swanie80 New Member
    B
    Here's what the manual says, not sure what I do when chains are required even with 4WD‍‍♂️
  10. Oct 16, 2023 at 5:32 PM
    Lift that bitch and make room!!
  11. Oct 16, 2023 at 5:43 PM
    Fever Buck
    2024 Tundra TRD Pro
    That’s crazy. Chains are a necessity during later hunting seasons out here.
