Roadactive Suspension
Discussion in 'Towing & Hauling' started by Rerun, Sep 15, 2023.
  1. Sep 15, 2023 at 7:55 PM
    Rerun
    Rerun [OP] New Member
    Rick
    Tucson AZ
    2019 Crewmax Limited TRD 4x4 white
    Just bought a new to me TT and it’s about 1k heavier than my old one. The seller said tongue
    Weight is about 450 lbs and GVW on the trailer is 6k. I doubt I would ever see 6k as we travel
    Very light. Truck is completely stock except for a rear sway bar. Would the RAS HD have any problems with the sway bar or does the sway bar need to be removed. I do tow with a WDH. Kinda new to this towing stuff; appreciate any suggestions and opinions.
  2. Sep 15, 2023 at 7:59 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    RAS should play fine with the swaybar, frankly I'm curious why you think you'd need it with a WDH anyway?
  3. Sep 15, 2023 at 8:06 PM
    Rerun
    Rick
    Tucson AZ
    Maybe I got ahead of myself a little bit. I pick up the trailer on Tuesday, maybe I should have waited until I towed it home. Just wanted to be informed in case the sag was more than I wanted. I appreciate the quick response….
  4. Sep 15, 2023 at 8:58 PM
    MedCityMoto
    I really don't think you'll need it! Fine tune in your WDH and you'll be golden, I'd wager. Doesn't sound like you'll even break much over half towing capacity!
  5. Sep 16, 2023 at 11:14 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Load the trailer how you will use it before setting WDH up!
    Clothes, food, dishes/cookware, water, trailer gear, etc.
    With that light of a trailer, id bet lunch that you’ll get all you need from a well adjusted WDH. My personal experience is with a Fastway G2, which manages my 7,200# trailer quite well.
    I have friends that use an Equalizer hitch, which looks very similar to my G2 but is available with heavier load bars if needed.
  6. Oct 16, 2023 at 1:48 PM
    Toytech6466
    Toytech6466 New Member
    Tracy
    Santa Cruz
    23 Tundra 1794
    I have installed about 200-250 RAS systems over the last 25 years, 90% on Tundras and Tacoma's. I run an independent Asian/Hybrid specialty shop and am also a Toyota Master technician.
    Your Tundra will handle better with the RAS on it. It will help in the wind, bumps, when Semis go by and any situation that you can think of. I have yet to have any customer complaint about the RAS system, except for it raising the rear up!!
    Hope this helps
    MotoTundra and bulldog93 like this.
