AC compressor?
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Oct 13, 2023.
  1. Oct 13, 2023 at 2:38 PM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Is the black ring forward of the belt supposed to turn when the AC is turned on? Mine doesn't, also, my AC doesn't work. Just seeing if that could be the problem
  2. Oct 13, 2023 at 2:59 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The compressor clutch won't engage if the Freon is low/empty.
    The Black Mamba likes this.
  3. Oct 13, 2023 at 3:02 PM
    Is it the outside part (clutch) that's not turning, or is the actually pulley wheel not turning?
    The clutch is supposed to lock intermittently, and not move, it's part of normal operation. EDIT: @w666 is totally right also. The pulley should be moving all the time. Everything you've ever wanted to know about auto A/C clutches:
  4. Oct 13, 2023 at 3:06 PM
    Aaol1
    Sam
    Pulley wheel is turning, clutch not turning ever, wether ac turned on or not
  5. Oct 13, 2023 at 3:14 PM
    Video shows how to test clutch operation. If clutch is moving in/out with voltage applied as shown, you're probably low on freon.
  6. Oct 13, 2023 at 3:25 PM
    Aaol1
    Sam
    Yep watched it, kk I'll try to give that a go
  7. Oct 13, 2023 at 5:32 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Thankfully our trucks are R134A, which is still readily available and fairly inexpensive compared to the 1234YF garbage newer cars a forced to use.
  8. Oct 13, 2023 at 6:46 PM
    Aaol1
    Sam
  9. Oct 13, 2023 at 7:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    KNABORES likes this.
  10. Oct 13, 2023 at 7:29 PM
    This ^^
    Don't try to fix on your own.
  11. Oct 13, 2023 at 8:25 PM
    Aaol1
    Sam
    Why not try to fix on my own @shifty` ?
  12. Oct 13, 2023 at 8:34 PM
    Don't try and fill your own A/C system.
    You don't have a good concept of how to install pressurized coolant into a system, or how to it check for leaks, don't have gauges or a means to vacuum the system, you have no place trying to refill your own stuff.
    It's easy enough to diagnose whether the system is working or not. If you have gauges and know how to use them, go for it, at least you'll know if a shop is screwing with you when you go. But don't run to the store and grab a can of refrigerant and try to fill your own system.
    FirstGenVol likes this.
  13. Oct 13, 2023 at 9:09 PM
    Aaol1
    Sam
    Yea I guess dealing with refrigerant is a different ball game. After completing my water pump / timing belt job successfully, I fell ready for anything haha. Maybe not this
  14. Oct 14, 2023 at 1:07 AM
    w666
    Maryland
    You can do this...but not without hundreds of dollars worth of specialized tools and equipment. AC service is ~$59 at your local garage.
  15. Oct 14, 2023 at 6:04 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    It wouldn't hurt anything to buy a can of Freon without any additives, a low side recharge hose for $12 and see what happens. It would cost you $25 to see if your A/C system works or you need a compressor and a system overhaul. If the system works but has a leak you can later add some freon with die to see if you can find the leak. I have this recharge hose from Amazon.
    https://www.amazon.com/dp/B085VH4D2Q?ref=ppx_yo2ov_dt_b_product_details
    Aaol1[OP] likes this.
  16. Oct 14, 2023 at 7:43 AM
    What you're describing though, it's the best-case scenario on one side, i.e. it actually holds the refrigerant, but it's a sealed system so ... if it's low, we already know there's a leak somewhere, however small, so the new coolant will leak out. On the worst-case side, there are no looks and it's holding coolant fine (i.e. it's not low), he may be doing more harm than good by over-pressurizing. This is why throwing gauges on it is important. Either way, he's spending time and money only to find out whether he has to take it to an A/C repair shop anyway to get work done, which is more time and money.
    This is one case where it's easier to cut out the middleman/work. Time is money all the same. OP is out at lest $30-40 minimum to buy the cheapest parts to throw refrigerant into the lines. Shops around me run $40-60 to test the systems for leaks and test for pressure then tell you the result if you use a specialty shop (I'd never got to an NTB or Firestone style shop for A/C work).
  17. Oct 15, 2023 at 1:56 AM
    w666
    Maryland
