Removing Tufskinz Bed Stamp Decals
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by nasher75, Oct 12, 2023.
  1. Oct 12, 2023 at 6:56 AM
    nasher75
    nasher75 [OP] New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I've remove lot's of badges in my day, but I'm wondering what your technique was if you ever removed the TRD Pro Bed Stamp decals? The fact that they are recessed, is giving me pause from threading monofilament through there and marring the paint on the bed surface.
    I will definitely start with a heat gun to soften the adhesive, but would appreciate tips on getting them started without causing other problems. This is the only reason they are still on.
    Bad Cow likes this.
  2. Oct 12, 2023 at 12:25 PM
    nasher75
    Erik
    Los Gatos, CA
    Well, I walked out to the parking lot and my truck had been sitting in full sun for a few hours. Was able to get a fingernail under the corner of one of the letters and it peeled off super clean. 3 minutes later and both sides are debadged and clean. Nice feature, if you ask me. Maybe Don had wax on the paint before they went on and that helped to make them easier to remove. They were still on very solid, but came off without fuss!
  3. Oct 12, 2023 at 3:02 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Glad you got them off with ease. Speaking for myself, I much prefer the stamped steel without decals, looks very industrial and clean.
    Piney, RainMan_PNW and bulldog93 like this.
  4. Oct 12, 2023 at 7:33 PM
    nasher75
    Erik
    Los Gatos, CA
    Yep me too
    Piney, Bad Cow and RainMan_PNW like this.
  5. Oct 13, 2023 at 12:29 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Hey Erik, It’s looks awesome. I was hesitant adding them but I new they would be easy to remove if need to. I think it looks good both ways. I agree the reason they came off easy because of me using a lot of ceramic spray I use from griots garage. Stuff works great. I also wiped the area before the install with alcohol.
  6. Oct 13, 2023 at 12:33 PM
    nasher75
    Erik
    Los Gatos, CA
    I agree the truck looks great either way. The Tufskinz are definitely a tasteful addition
