Only gauges working are fuel and battery, already checked the fuses and replaced cluster
Discussion in '2nd Gen Tundras (2007-2013)' started by agarcia102, Oct 9, 2023.
  1. Oct 9, 2023 at 2:36 PM
    agarcia102
    agarcia102 [OP] New Member
    2007 Tundra Limited 5.7
    We have a 2007 tundra limited 5.7 the only gauges working fuel and battery on cluster we checked fuse replaced cluster and can’t get any communication with engine and transmission but truck still runs.
  2. Oct 11, 2023 at 7:13 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Communication network is down. Check for short in wiring.
    I think a bad wheel speed sensor can cause this somtimes.
    Wynnded likes this.
  3. Oct 12, 2023 at 2:35 PM
    agarcia102
    Okay makes sense customer just told us it happened right after they got the truck unstuck
    In the mud but we did find a blown fuse it was met 745 amp
