4runner axle swapped to tundra...
Discussion in '1st Gen Tundras (2000-2006)' started by Brokebloke, Oct 10, 2023.
  1. Oct 12, 2023 at 9:02 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
  2. Oct 12, 2023 at 9:06 AM
    Y'all derailed this thread badly.
    bmf4069 likes this.
  3. Oct 12, 2023 at 9:14 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Should be noted there is a typo on it. 05-06 Tundras do NOT have a 8" front diff. They have the same 7.5" reverse clamshell the 00-04s have.
    I want to say the 8" factory e-lockers came with 4.30 gears, but I could be wrong on that. Either way the front diff has to match. Regarding using the 8" carrier in an 8.4" housing, this is what they have to say:
    "It cannot be easily retrofitted into a T100/Tundra or open-diff Tacoma style axle housing because the mounting bolt pattern is smaller. It "could" be done by an axle builder by doing major work to the mounting flange, but that is not really a practical option."
    whodatschrome[QUOTED] likes this.
  4. Oct 12, 2023 at 12:37 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Just the ring and pinion maybe. You'll probably need a conversion pinion flange.
