Can you switch a factory leaf spring hanger bolt to a grade 8 bolt?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Marshwalker, Oct 11, 2023.
  1. Oct 11, 2023 at 3:39 PM
    Marshwalker
    Marshwalker [OP] New Member
    Z
    Back story,
    Installing torklift front mounts for my slide in camper. After install, not much of the original nut threads on the bolt through front leaf spring mount. They are soft and I stripped one. Going to replace when I put new HD leaf pack in a couple weeks. Replace with a new stock bolt, or could a grade 8 bolt little longer same diameter also work?
    curious about weight and stress. Pics included
    Thanks guys
  2. Oct 11, 2023 at 6:33 PM
    Marshwalker
    Z
    Any ideas?
  3. Oct 11, 2023 at 7:26 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    A little longer bolt would be fine, probably a better option than original,get one enough to put a lock washer on should be good to go
  4. Oct 11, 2023 at 7:29 PM
    Get an appropriately sized shoulder bolt if available. Should be fine.
    Marshwalker[OP] likes this.
  5. Oct 11, 2023 at 8:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes, as others have mentioned make sure the it’s shanked properly and you’ll be fine.
  6. Oct 12, 2023 at 4:10 AM
    Marshwalker
    Z
    Dumb question.. shoulder that mean the thick ness
  7. Oct 12, 2023 at 4:36 AM
    shoulder bolt has a solid shaft and threads on just the end. Stronger and smoother in the middle. Here’s a pic that shows one with a shoulder. Obviously you want the shoulder on yours longer to span most of the distance across the leaf spring bushing.
  8. Oct 12, 2023 at 5:13 AM
    Retired...finally
    Remember the standard is a minimum of three threads showing past the nut. I would consider the bolt in your picture to be unsafe. Moving to a harder grade bolt usually does not present a problem.
    cran2 likes this.
  9. Oct 12, 2023 at 7:21 AM
    Marshwalker
    Z
    Ya pretty shitty by tork lift to make that happen with and not have a fix
