I want to convert factory driving lights to amber fog lights.
Discussion in '2.5 Gen Tundras (2014-2021)' started by MountainMan, Oct 10, 2023.
  1. Oct 10, 2023 at 1:05 AM
    MountainMan
    MountainMan [OP] New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    Should be easy. I have factory LED lighting for headlights and driving lights. I just want to replace the factory LED driving light bulbs with aftermarket amber LED bulbs. Been searching all over the forum and internet and can't figure out which style LED bulb are OEM.
    Any ideas?
  2. Oct 10, 2023 at 6:16 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What do you mean exactly by “driving light”
    BravoDeltaRomeo likes this.
  3. Oct 10, 2023 at 6:23 AM
    RainMan_PNW
    Casey
    Clark County, WA
    The 2021 LED headlight is a sealed assembly. There are no bulbs to replace in it except the amber turn signal. Everything else is a manufactured unit… if the LED goes for some reason, the whole headlight assembly gets replaced (or maybe you try DIY replacing individual LED chips, but I’ve yet to see someone do that).
    if you are wanting amber DRL lights (the C-Shape) then I think @TRDFerguson recently got some aftermarkets from @memario1214 that are set up that way
    1lowlife likes this.
  4. Oct 10, 2023 at 6:28 AM
    RainMan_PNW
    Casey
    Clark County, WA
    And if you are referring to the fog lights, those are also a self-contained unit. Either some amber vinyl over the lens, or replace the fogs with amber aftermarket setups like Baja Designs Squadron SAE or Diode Dynamics SS3
  5. Oct 10, 2023 at 7:00 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Very pleased with my Baja Designs Squadrons in the factory fog location. I didn’t go with the SAE option that was available when I bought, but understand that the newer version is better and brighter than the original SAE.
    For what it’s worth, I rarely get light flashed from oncoming traffic with my Squadron Sports and wide cornering amber lenses.
    SAE kit for your truck:
    https://www.bajadesigns.com/products/toyota-squadron-r-sae-fog-pocket-light-kit-toyota-2010-23-4runner-2012-23-tacoma-2014-21-tundra/
    Non-SAE:
    https://www.bajadesigns.com/product...21-4runner-2012-2021-tacoma-2014-2021-tundra/
    Baja Designs likes this.
  6. Oct 10, 2023 at 10:24 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @MountainMan,
    If you are looking for a fog light replacement. I would recommend checking out our direct fog light kit for the Tacoma. As @Chad D. mentioned we do have two different kits one being SAE and the other being an OHV light. With our newer SAE fog light replacement, we utilize a new optic that allows 56% more light output than our gen 1 SAE as well as creating a sharp cut-off. If you have any questions about our product, please feel free and reach out.
    @Chad D. how are you enjoying our Squadron Sports? Are you running any of our other lights on the truck?
    Best,
    Bill Sonevongxay | Forum Sales & Support 
    Email:
    Bill@bajadesigns.com Phone: (760)560-2252
    whodatschrome and PermaFrostTRD like this.
  7. Oct 10, 2023 at 10:26 AM
    MountainMan
    2021 1794 Edition
    Driving lights are the auxiliary lights other than the headlights located lower in the bumper. Fog lights are the same lights, but only if they are amber or a specialized beam designed for fog. At least that's the most commonly used terms I've seen used in 40 years of driving and being in the automotive industry.
    I know some people call them fog lights, even when white, but that's incorrect, IMO.
  8. Oct 10, 2023 at 10:34 AM
    18" TRD Off Road Wheels
    The common term for the lights in the bumper is fog lights, and that is across the board. Their efficacy aside, that is the common term, and that is why people were confuse. There's lots of options for amber fog lights.
  9. Oct 10, 2023 at 12:48 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I’ve got a few…
    https://www.tundras.com/threads/more-light-please.131554/
    Plus the S1’s flush mounted in the rear bumper and (4) Squadron Sports with work/scene lenses on the tractor…
    Just got the S8 back in the mail from a quick warranty fix yesterday.
  10. Oct 10, 2023 at 12:51 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    OP is right…. Driving lights are often called fogs. And the other way around!
    I think the industry has migrated toward the term “fog” more than driving, so that’s what we typically call ‘em. Kinda like, when the hell did ditch lights start getting called ditch lights? Mine aren’t aimed in the ditch, so am I wrong???
  11. Oct 10, 2023 at 12:57 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    IMG_5257.png Potato,,,,,,,, tomato? WOW! Fog lights even on the Toyota website I believe they are called FOG lights. Holy Moly:)
  12. Oct 10, 2023 at 1:01 PM
    Black@Blue19
    Ken
    SE Texas
    My suggestion would be this above or pull the bulb that you want to replace and then go from there with what ever color you want to replace them? Plenty of info out there about replacing them with the amber units. Or the bulb.
    my daughter replaced the whole unit with just a little help so I know it isn’t that hard,,, and I was the little help.
  13. Oct 10, 2023 at 1:43 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Assuming Toyota didn’t go backwards, the OP’s truck should have LED fog (driving?) lights. No bulb to replace.
    Edit: I just reread the original post. LED fer sure. Time to replace the whole shitaree.
  14. Oct 10, 2023 at 2:03 PM
    Black@Blue19
    Ken
    SE Texas
  15. Oct 10, 2023 at 2:19 PM
    Baja Designs
    San Marcos, CA
    Hey @Chad D.,
    How's the S1 working out as a chase light or work light? (4) Squadron Sports on a tractor! That sounds rad, do you mind sharing some photos of that? Would love to see them mounted up on that thing.
    Best,
    Email: Bill@bajadesigns.comPhone: (760)560-2252
  16. Oct 10, 2023 at 3:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    In the trucks with LED lights, there is no bulb to pull. It is a single unit - housing and all.
    PermaFrostTRD likes this.
  17. Oct 10, 2023 at 3:58 PM
    Black@Blue19
    Ken
    SE Texas
    Well then there ya go. Replace both the FOG Lights :)
  18. Oct 10, 2023 at 4:35 PM
    MountainMan
    2021 1794 Edition
    Ordered the Lamin-X coating to turn my driving lights into FOG lights...:D
    KNABORES, Sierradevil and Gene_in_FL like this.
  19. Oct 10, 2023 at 6:12 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    It’s definitely money, but the OEM lights do not hold a candle to a good set of high end retrofit lights.
    A coating will make them yellow, but the OEM just doesn’t do much. Even the LED ones. Totally cool if you’re just wanting yellow, but don’t expect much performance!
  20. Oct 10, 2023 at 9:34 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    So you’re changing the color of your fog lights from factory to amber? What’s the benefit?
  21. Oct 10, 2023 at 10:16 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Amber colored fog lights you say? Here’s the cheap and quick way of doing it. Just a few minutes worth of arts and crafts and your old lights will be cutting through the fog while blasting offroad at 60mph!
    TOYOTARIG and PermaFrostTRD like this.
  22. Oct 10, 2023 at 10:42 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    That used to work, but not since Sharpies went non-toxic a few decades ago. Sure, they still have a Prop-65 warning, but so does a glass of water.
    g6t9ed and whodatschrome[QUOTED] like this.
  23. Oct 10, 2023 at 11:44 PM
    MountainMan
    2021 1794 Edition
    PermaFrostTRD and AZBoatHauler like this.
  24. Oct 10, 2023 at 11:47 PM
    AZBoatHauler
    So.Arizona
  25. Oct 11, 2023 at 4:44 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Ah. I didn't realize those were considered Amber. I always thought of amber as like turn signal color. I knew about the yellow lights being better for driving in certain conditions. Just like having yellow glasses for target practice or certain construction.
  26. Oct 11, 2023 at 12:49 PM
    whodatschrome
    lots of dents
    Here in the PacNW we get all sorts of weather...driving rain, dust, dense fog, heavy snow, ect. If you use the clear lens BD leds in those conditions, it can be detrimental to safely seeing the roads (or obstacles in the road). Their amber (yellow colored) lens helps alleviate that. Yes you do loose some usable lumens, but what you get back in return is better lighting. I’ve noticed that all of the BD clear lenses (spot, driving combo, wide cornering) can be detrimental in some of those really bad weather conditions. I have absolutely zero experience with their new SAE Squadrons, so i can’t speak on with them in particular. I must have anywhere from 30~40 Baja Designs lights on all sorts of vehicles, motos, and a JD garden mower (no, i’m not exaggerating on the numbers), so i’m fairly well versed with them. Plus i’ve installed around 20 more Squadrons and S2’s on family and friend’s
    vehicles/motos. I primarily use a pair of Squadron Sport Amber wide cornering as my fog lights. If it starts snowing really hard and you have a clear lens (on say a Squad Pro or a OnX light bar) blasting on high, your view through the windshield will be exactly sitting next to Chewbacca on the Millennium Falcon as it’s traveling through Hyperspace. The light reflects off of the individual snowflakes that are coming at you at 55mph. And that’s the reasoning behind the amber lens.
    Living in the PacNW makes me want to get a pair of the new style SAE Squadrons. But i think i would prefer some sort of SAE/ normal lens combo though...the bottom two LEDs be the SAE version, while the top two be the normal Pro spot lens.
    AZBoatHauler and MountainMan[OP] like this.
  27. Oct 11, 2023 at 2:00 PM
    Baja Designs
    San Marcos, CA
    Hey @whodatschrome
    We appreciate the continuous support of our products. It's rad to hear all of the variety of different Moto applications you utilize our product on. Would love to see the garden mower with the Baja Designs lights on it! If you are interested in placing an order for our new SAE feel free to send me a PM.
    With the topic of amber and clear, I will go ahead and link our page with detailed information about this topic.
    https://www.bajadesigns.com/amber-vs-clear-what-is-the-difference/?vid=147446
    Best,
  28. Oct 11, 2023 at 2:13 PM
    AZBoatHauler
    So.Arizona
    Great thing about @Baja Designs is the serviceable lens so you can go back and forth. I’ll run clear when dust/fog/snow isn’t a concern just based on preference of light color.
  29. Oct 11, 2023 at 3:36 PM
    Baja Designs
    San Marcos, CA
    Hey @AZBoatHauler
    Appreciate you rocking with Baja Designs on the truck. The front bumper you have in the second picture really sets off the front end. How are you enjoying your lighting setup?
    Best,
    AZBoatHauler[QUOTED] likes this.
  30. Oct 11, 2023 at 3:43 PM
    AZBoatHauler
    So.Arizona
    Love everything I have from you guys. Currently running the SAE fogs, S2 Ditch lights, and S1 chase lights. You guys were extremely helpful getting me the right bezels when I switched bumpers saving the hassle of buying and selling different sets. Need to save some more pennies so I can replace that RC with a 30” S8 or throw some LP6s on the bumper.
