WTH is this bolt??
Discussion in '2.5 Gen Tundras (2014-2021)' started by MGMTundra18, Oct 7, 2023.
  1. Oct 7, 2023 at 5:01 PM
    MGMTundra18
    MGMTundra18 [OP] New Member
    Charlotte NC
    2018 MGM Tundra 4x4 TRD Sport
    I was doing an oil change today and when I removed the filter housing, this little black bolt dropped out as well. Where is that from, is it even from the truck? It's tiny.
  2. Oct 8, 2023 at 7:28 AM
    Chip_Tundra
    Chip_Tundra New Member
    Yikes. Maybe during assembly a random screw was just in the oil pan floating for a long time. It looks like it got through the pick up screen and the filter saved it from ruining your engine. If the truck is running ok, I wouldn't worry about it. Just my opinion.
  3. Oct 8, 2023 at 7:35 AM
    Extra yikes.
  4. Oct 8, 2023 at 8:06 AM
    coTony
    Tony
    Montrose, CO
    did you wipe the oil off the bolt? Does not look wet so just wondering if maybe it was dropped from above and stuck in a spot and came out when the filter housing was removed. That is very weird
  5. Oct 8, 2023 at 8:14 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Torx or Hex drive?
  6. Oct 8, 2023 at 8:17 AM
    MGMTundra18
    Charlotte NC
    Good catch on the oil and it being clean. I didn't wipe it down, so chances are it didn't come from inside the engine. Maybe just was sitting on the skid plate and dislodged it removing the filter housing? Truck is still running good.
    NewImprovedRon likes this.
  7. Oct 8, 2023 at 8:19 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I would agree with your speculation on it getting dislodged. Otherwise, it would have probably come out with previous oil/filter changes.
  8. Oct 8, 2023 at 8:21 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That honestly looks like a bolt that would have come out of one of my firearms..:eek:
    coTony likes this.
  9. Oct 8, 2023 at 8:22 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd say the blue loctite didn't work for sh1t
    Wynnded, coTony, 1lowlife and 2 others like this.
  10. Oct 8, 2023 at 8:27 AM
    MGMTundra18
    Charlotte NC
    It's got a T8 torx head on the bolt.
  11. Oct 8, 2023 at 8:34 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Tiny little thing.
    From that photo it doesn’t look to have been installed. Normally there’s some degradation of the loctite when I remove things like that.
  12. Oct 10, 2023 at 9:07 PM
    DowntownApexTundra
    DowntownApexTundra New Member
    2021 DC SR5 4x4 Sport
    3/2 leveling lift kit, pocket style fender flares (best super white color match you'll ever see - painted by my uncle), 1.5" wheel spacers, S&B CAI, TRD Pro headlights, 18" knockoff Ebay TRD Pro Wheels, wildpeak at3w 275/65R18 116t (32/11), gator roll-up tonneau, blacked out interior by AJT and others, pedal commander, blacked out exterior badges, LED everything, RCI neoprene water proof seat covers (removed back middle seat back material to make it work), weather tech floormats, flowmaster flowfx extreme 3.0 exhaust
    Looks like a T8 from an older HP, Lenovo, or Fujitsu laptop.
    patterson.walter likes this.
  13. Oct 10, 2023 at 9:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    thats the bolt from the ratchet you were using i bet... looks just like a bolt on a typical ratchet assembly
  14. Oct 11, 2023 at 3:27 AM
    Bammer
    Monroe, CT
    I think you nailed it !
  15. Oct 11, 2023 at 8:35 AM
    MGMTundra18
    Charlotte NC
    Well I'll be.. That was it! Mystery solved and anxiety levels lowered. Appreciate the responses.
  16. Oct 11, 2023 at 8:36 AM
    F’n nailed it
  17. Oct 11, 2023 at 8:43 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    You should be a private investigator or detective.......that's amazing man!!!!!!
  18. Oct 11, 2023 at 8:44 AM
    Wish we could have the audio of him saying that…..
    AZBoatHauler likes this.
  19. Oct 11, 2023 at 9:08 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  20. Oct 11, 2023 at 11:02 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    It's the internal adjustment bolt that they use to set mpg at the factory.
    Now your mpgs are gonna suck.
    ZappBrannigan and Saltyhero13 like this.
  21. Oct 11, 2023 at 11:37 AM
    coTony
    Tony
    Montrose, CO
    When I first seen that bolt I thought it looked familiar but I could not pin it down. You nailed it!!! :bowdown:
    empty_lord[QUOTED] likes this.
