LCD display
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shake n bake1208, Oct 10, 2023.
  1. Oct 10, 2023 at 5:25 PM
    Shake n bake1208
    Shake n bake1208 [OP] New Member
    Hey all. My lcd display in my 2014 tundra went completely black. Does not come on at all. Also my usb port and my 12v(cig lighter sockets) also don’t work. I have checked continuity on every single fuse both under the hood and in the cab and I’m all good on the fuses…just wondering if anyone has any insight as to what to check next. Is there a wiring harness that connects all that to the display by chance? I’m kinda pulling at straws at this point. Any help is greatly appreciated!
  2. Oct 10, 2023 at 6:26 PM
    NoRcptn
    NorCal
    2017 Platinum
    It's been a while since I've torn mine apart. That would seem logical that they're in the same harness since the usb is connected to the stereo. You could always pull it apart and check the harness to make sure it's all plugged in properly the back of the stock stereo . The 12 v cig lighter is throwing me off though. Hopefully someone can chime in that's had that problem. But in the meantime ....,
    https://www.youtube.com/watch?v=8dj_XF3Qwgk
