I have the same problem and used GM style push pins that hold the kick panel in place.
Discussion in 'General Tundra Discussion' started by Bourru50, Oct 10, 2023.
  1. Oct 10, 2023 at 8:20 AM
    Bourru50
    Bourru50 [OP] New Member
    Kirk
    White Tundra 4 by
    2022 tundra kick panels use GM style push pins and problem solved. The OE pins blow.
  2. Oct 10, 2023 at 8:35 AM
    18" TRD Off Road Wheels
    The same problem as what? :confused:
  3. Oct 10, 2023 at 11:58 AM
    Bourru50
    Kirk
    White Tundra 4 by
    Kick panels coming loose and shifting. It was my first post not sure I got the right thread.
  4. Oct 10, 2023 at 12:03 PM
    All good. You created your own thread so there's no other issue to reference. If you want to respond in to an existing thread or comment your best bet is to use the "quote" button in the bottom right of the comment that you wish to respond to. It makes it's easier to follow for you and us. :thumbsup:
