2008 Tundra 4hi light flashing
Discussion in '2nd Gen Tundras (2007-2013)' started by Ramit58, Oct 10, 2023.
  1. Oct 10, 2023 at 10:55 AM
    Ramit58
    Ramit58 [OP] New Member
    Shayne
    So here is my problem when I attempt to engage my 4wd I can hear the transfer case actuator engage but the light only flashes. I replaced the front add and the 4wd control module. But the issue continues, has anyone else had this problem and if so how did you fix it. Thank you.
  2. Oct 10, 2023 at 10:58 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Did you do anything to it before it stopped working? Do you have any other warning lights lite on the dash?
  3. Oct 10, 2023 at 11:00 AM
    Ramit58
    Shayne
    No it was working fine then when I went to engage the 4wd is when everything went down hill there are no other lights on. It’s also not throwing any codes.
