2015 Trd pro hauling/leveling
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Robthecloud21, Oct 5, 2023.
  1. Oct 5, 2023 at 9:51 PM
    Robthecloud21
    Robthecloud21 [OP] New Member
    Ontario
    2015 Tundra TRD Pro
    Hi everyone. I’m in the process of purchasing a 2015 TRD pro which I had been drooling over ever since it was introduced.
    Anyway, I do plan on doing some towing with it. Between 4-6000 lb camping trailer.
    I’ve read that because the suspension is so compliant and that because the truck sits so level, it does squat a bit more than some would like.
    My current tundra has a 3 inch leveling kit in the front with blocks in the rear so that it still has a decent amount of rake.
    The question is, can I simply add blocks to the rear or the Trd pro without sacrificing too much suspension?
    Any other ideas and experiences with the TRD pro are welcome to be shared. Thanks
  2. Oct 5, 2023 at 9:56 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    toyota-tundra-1999-2020-hd
    Terndrerrr likes this.
  3. Oct 6, 2023 at 5:06 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I have Firestone airbags on mine and they work great for leveling while towing. I tow around 5,000 lbs.
  4. Oct 9, 2023 at 10:49 AM
    Robthecloud21
    Ontario
    2015 Tundra TRD Pro
    Does the RAS raise the ride height a little. I’d like to add a like rake if I could. Looks like the best option so far but I’d like it to raise the rear end a half inch or so.
  5. Oct 9, 2023 at 11:10 AM
    Tripleconpanna
    Yes...
    Spend some time in this thread and you'll see feedback from several members w/various setups.
    Roadmaster Active suspension review
