Alignment before or after new tires
Discussion in 'Wheels & Tires' started by tightywhitey, Oct 8, 2023.
  1. Oct 8, 2023 at 5:46 PM
    tightywhitey
    tightywhitey [OP] New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I need new tires and have some uneven wear on the inner side of my front tires. Should I get an alignment first before getting new tires?
  2. Oct 8, 2023 at 5:50 PM
    RobertD
    Robert
    DFW, Texas
    After
    T-Rex266 likes this.
  3. Oct 8, 2023 at 5:53 PM
    RobertD
    Robert
    DFW, Texas
    Why would you do it before? The new tires will likely be a different size then the current (even if their numbers are the same, you are dealing with wear vs new), why would you not wait and have the alignment done on the actual tires you are going to be driving on?
  4. Oct 8, 2023 at 5:56 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    Tires shouldn't be a variable in alignment, but why not just do it after? If you have uneven wear, why do that to a new set of tires that ruined the old set?
  5. Oct 8, 2023 at 6:03 PM
    tightywhitey
    New Orleans, LA
    I have had issues locally getting a good alignment. I was thinking maybe get the alignment dialed in then replace the tires.
