  1. Oct 5, 2023 at 4:15 AM
    War Machine
    War Machine SSEM # 5 3MW
    Looks like you just need to unscrew that piece and put the new one on. That plastic part tends to dry rot so unless it’s still good you may as well swap that too.
    joseph_womack likes this.
  2. Oct 5, 2023 at 4:18 AM
    War Machine
    Put some Tyger blade running boards on. The old ones were trashed.
    Also put some cheap Amazon door handle overlays on to get a gloss black look. We’ll see how they hold up.
    D4x4TRD, Mountun Goat, Fotnot and 5 others like this.
  3. Oct 5, 2023 at 6:59 AM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Nice. I’ve had those running boards for over a year now, no complaints or signs of rust.
  4. Oct 5, 2023 at 10:56 AM
    War Machine
    I had them on a previous truck. No issues at all.
    Skew12[QUOTED] likes this.
  5. Oct 5, 2023 at 4:28 PM
    cwcore
    cwcore New Member
    2007 SR5 DoubleCab Long Bed
    New wheels & got it detailed, hit 48,800miles
    Waiting on dirty deeds exhaust ordered on August 25th
    D4x4TRD, 07 Tundie, chugs and 8 others like this.
  6. Oct 5, 2023 at 5:38 PM
    Retroboy1989
    Northern Utah
    I kick myself everytime I see these wheels on a second gen. I could have had a set for $500 with ok tires. Deal of deals to miss out on.
    07 Tundie and Tripleconpanna like this.
  7. Oct 5, 2023 at 9:15 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Updated the interior lighting with VLEDS lighting. I don't know how I've gone so long without decent cab and footwell lighting! Just waiting for the puddle lights to arrive.
    D4x4TRD, Jego, 07 Tundie and 8 others like this.
  8. Oct 6, 2023 at 11:27 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Finally got my climate control servo replaced. What a freaking nightmare of a job. You pretty much need to be a contortionist with 3 hands in order to do this job.
  9. Oct 6, 2023 at 1:56 PM
    Cmende
    Cmende New Member
    California
    2013 Rock Warrior
    Dirt King boxed upper and lower control arms. Fox 2.5 shocks front and rear. R1 concepts drilled and slotted rotors. Baja Designs XL80 on the A-pillar and Baja Designs Squadron Pros in the fogs.
  10. Oct 6, 2023 at 2:41 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    This is what it looks like with the antenna removed. You should be able to unscrew the rest of the antenna and install a new one. A little penetrating oil and some time might help.
    MTRock and joseph_womack like this.
  11. Oct 7, 2023 at 10:57 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I replaced all four belt moldings around the windows. Took less than 15 minutes. No more flapping in the breeze from the old, ripped up ones.
    War Machine and PhotoNerd like this.
  12. Oct 7, 2023 at 2:38 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    I did NOT install steering wheel controls.
    I got them wired up and discovered that the extra temperature control buttons on the right panel don't pass signals through to the stereo. I think they communicate directly with the automatic climate control system, which my SR5 doesn't have.
    So I'm returning these controls and ordered the standard kind with fewer buttons, along with the narrower airbag I need to fit them onto my wheel.
    I'll make a DIY when I'm done because the existing DIYs on the topic are scattered and confusing.
  13. Oct 7, 2023 at 5:03 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I did the Auto Climate Control upgrade on my SR5. The dash parts and specific Climate Control ECU were from a Tundra, but my steering wheel was from a Sequoia, and it had the Temp controls (I've never noticed if the Tundras have them). FWIW, with the headlight on, the temp buttons won't illuminate like the radio controls do. I suspect that for the Temp controls to work with the ACC system, a Sequoia climate ECU may be needed.
  14. Oct 7, 2023 at 5:10 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Post up more info on how this is accomplished, parts and a price?
    I’ve read threads on steering wheel controls and it seems like a pain in the ass. Also my SR5 is not presided for a light sensor on the dash so I’m guessing it’s a lower level sr5?
  15. Oct 7, 2023 at 5:15 PM
    ultraman29
    ultraman29 New Member
    Katy Tx
    2021 White TRD sports
    Replaced the TRD pro strut spring from stock to Eibach E30-82-079-04-20.
  16. Oct 7, 2023 at 5:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I purchased the parts second-hand. I don't recall price exactly as it was quite a while ago. I don't see what year your truck is, but I don't know that anyone has done the conversion on a 2.5 Gen, this only applies to the 2nd Gen. Here's the thread that I followed:
    https://www.tundratalk.net/threads/automatic-climate-control-upgrade.221626/page-2
  17. Oct 7, 2023 at 6:04 PM
    PhotoNerd
    Tony
    Waterford, CT
    The threads do make it seem like a PITA but this is one of the easier mods I've done. Tap 3 wires in the steering column with vampire taps. One goes to ground and the other two poke info the back of a harness behind the head unit. Then swap your airbag and plug-in the buttons.
  18. Oct 7, 2023 at 6:11 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    it’s actually really simple.
    I bought the controls and airbag with cutout for them and plugged them up and mounted everything back together
    then just followed this. Ran wire from steering wheel connector straight to my pac like in the directions and everything worked fine
    Adding the auto headlights was easy enough as well, but just make sure to use the correct gauge wire mentioned in the how to floating around!
    Wynnded likes this.
  19. Oct 7, 2023 at 7:59 PM
    Tundra1D6
    2008 SR5, I’m not prewired with the solar sensor for auto headlights. Reading up on this if you don’t have that wiring it’s more involved to add auto climate controls. Something to do with the solar sensor and retaining temp when the truck restarts. Wish it was that simple ?
  20. Oct 7, 2023 at 8:22 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    20231007_121440.jpg Me and mobile device are not doing well. This picture landed on top somehow. Anywho, I let it drain till it barely dripped. Dropped the pan and a quart of fluid remains in the pan.
    2010 4.6 likely had its first dump and fill of ATF at 111,000 miles. Its towed throughout its life, shifts well and no issues. Took about 3 hours. Greased the 5 u-joints, cleaned things up along the way.
    Shifts solid and swift. Fluid was Amsoil. 6 quarts out, 6.5 in to overflow.
  21. Oct 7, 2023 at 10:30 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine wasn't wired for the solar sensor either. I had to add that for the addition of the auto headlights, the climate control and the extra wiring harness for temperature retention.
  22. Oct 8, 2023 at 7:50 AM
    rphass17
    rphass17 New Member
    thanks for that pic. I hit it with some kroil and it started breaking apart some plastic. I’m sure it will be stuck forever and I’ll have to buy a new mast.
  23. Oct 8, 2023 at 7:53 AM
    rphass17
    rphass17 New Member
    Yesterday I attempted to refinish my headlights with the 3M kit. It worked okay. Also replaced my turn signal bulbs.
    Mountun Goat likes this.
  24. Oct 8, 2023 at 8:32 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Yep, been a while.
  25. Oct 8, 2023 at 11:50 AM
    Retroboy1989
    Northern Utah
    Any snapped bolts?
  26. Oct 8, 2023 at 3:29 PM
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
    2008 Double Cab SR5 TRD
    Looking forward to that DYI I find myself thinking about this mod every single time I reach over to skip a song or adjust volume
    Zebruaj likes this.
  27. Oct 8, 2023 at 8:59 PM
    KeepOnTruckin
    Randy
    NW truck, no salt, no crazy underneath. Having removed 10,000+++ pan bolts working at AAMCO for ten years, transmission pans inherently seep through the gasket. It's rare but not impossible for pan bolt to corrode in place.
    Use a 1/4" speed handle to break them free. The speed handle has feel. Trust it. Just like tightening a bolt and SEEING when it quits turning, common sense (for some) says quit turning when it stops cold.
    It was eventless. Well until 24hrs later I see new crush washer leaking... - sigh - At least it's the overflow plug 100 miles later. Still a good amount of seepage. :mad:
  28. Oct 8, 2023 at 9:12 PM
    KeepOnTruckin
    Randy
    After 100 miles both ways on ATF fluid swap I'm happy to see the 4.6 2010 with 110k miles does this with STFT / LTFT at 77 mph on the interstate. Never mind that other jazz.
    Zero / Zero across the board.
  29. Oct 8, 2023 at 10:10 PM
    Retroboy1989
    Northern Utah
    What's the relationship between transmission performance and fuel trim? Why is 0% a good thing?
  30. Oct 8, 2023 at 10:39 PM
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
