What to worry about on a truck thats been sitting since 2012
Discussion in '1st Gen Tundras (2000-2006)' started by Kraken, Oct 7, 2023.
  1. Oct 7, 2023 at 5:24 AM
    Kraken
    Kraken [OP] New Member
    Paul
    Since the last couple Tundras I looked at fell through, I'm looking at another one. It's a 2000 Access Cab still V8 and 4WD. is the listing on FB. It's missing some parts, but he says it has a "new" (in 2012) frame, new tires and a new timing belt. And I added frame pics.
    I pulled the Carfax on it and it had 251,960 miles in 2012 and only went up to 256,115 when the current owner bought it in 2022. The new owner has put 8000 miles on it since purchasing. What things should I be concerned about on a truck that sat for that long?
    387525256_829222535245081_7432062510484838640_n.jpg 387342464_283159397870504_1611656927769594767_n.jpg 371432459_283577267928966_3896779761002875199_n.jpg 385493533_1472311906643926_1530298668982272241_n.jpg 387495487_343671851445247_5074988937531064812_n.jpg 385501391_605064751606707_7131959832771832511_n.jpg 387322398_879429470498439_5883259459587951153_n.jpg 385495539_637315398387392_1657013259141095968_n.jpg 386885051_688106610048144_6314199000703261681_n.jpg
  2. Oct 7, 2023 at 5:32 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Above my pay grade to advise on anything. Decent looking truck for the $, maybe question why the new owner is selling it after only driving 8k miles?
    Kraken[OP] likes this.
  3. Oct 7, 2023 at 5:45 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    I wouldn’t call that sitting, I mean 8k miles isn’t nothing. And the 200k-plus before that means it was definitely broken in. And how did they do those 8k miles? That could have been a handful of long trips, or 2,000 trips to the corner gas station to buy smokes and beer - those short trips can be bad for valve corrosion, she shifty’s stickied “So you bought a…” post section on low miles vehicles. I think the other usual issues are seals and gasket material drying out and cracking.
    Geezer likes this.
  4. Oct 7, 2023 at 5:52 AM
    Kraken
    Paul
    I'm not really worried about the 8000 miles in the last year. Its the 4000 miles between 2012 and 2022 that scare me.
    Weagle likes this.
  5. Oct 7, 2023 at 6:01 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    I read wrong, sorry. I think the logic still stands. Check out that post where shifty has collected pictures of dudes’ valves, especially the one closest to the driver (8?), the get grody and really varnished from stop and go short trips.
    Kraken[QUOTED][OP] likes this.
  6. Oct 7, 2023 at 6:40 AM
    turn005
    turn005 New Member
    Ensure all fluids have been replaced by new owner. Verify operation of everything to ensure no electrical issues. Rodents like nesting in idle vehicles and snacking on electrical wire insulation.
    NewImprovedRon and Kraken[OP] like this.
  7. Oct 7, 2023 at 8:16 AM
    shifty` Animals and insects don't do drugs
    FWIW, I've had mine more than 4 years, put about 12k miles on it (total). I'm the 3rd owner of my truck. The truck has 75k miles on it (total). It is what it is. And it was considered a fleet/business truck because the original owner bought it as a "company" truck ... he worked at a bank, and this was his daily driver to make the short few-mile partially-dirt-road trek to and from work every day. Based on your comments, I wonder what potential 4th owners would say about my truck when considering purchase?
    My reality is, if I needed a highway warrior, I wouldn't have bought a truck. I use my truck as a truck: Landscape/yard/utility, and fishing/camping/outdoor. I use it for a truck more than 75% of the other dudes in my neighborhood who have one but sure as hell don't need it. That's one of my pet peeves: Dudes who buy trucks just to check of the "yup, got a truck" man-cred box.
    But back to the point of the post... Maybe the previous owner got their use and moved on?
    @Kraken, I may not have any better insight than others on this, but off the cuff, here's my thoughts.
    You're got three considerations here: Metal degradation, mechanical degradation, electrical degradation.
    If you're concerned about mechanical degradation - timing belt, axles, driveline, suspension and steering, etc. - or electrical degradation - rodent damage, gremlins like corrosion inside connectors, water intrusion into circuits inside the cab, etc. - get a pre-purchase inspection (PPI) with a dedicated Toyota shop. They'll tell you everything you need to know. Change all fluids to get a baseline for maintenance when you get the truck. Don't forget to confirm 4HI engages before purchase.
    I think the bigger thing to address here that'd be highest on my concern list is metal degradation. If the frame was in bad enough shape it warranted a replacement, you need to understand to things. First, all the stuff that does not get replaced during frame replacement, any bolt that went un-turned, any steel bracket under the hood, any suspension component like the knuckles that are raw steel, things like O2 sensors ... you will be fighting with those things later down the road when you go to remove them. You will stockpile Kroil or PB Blaster and learn to use it religiously. Second, there will be body rot and other rotten stuff. The body stuff won't be outwardly visible at simple glance, you'll find it hiding under flares like this, which ultimately turns into this (reply #12 is a truck with his frame replaced, and he's currently cab-swapping because his cab corners/rockers are toast also). Here's why/how it starts. You'll have it in the cab corners and rockers eventually too, like some of our Kentucky members have. Any bare steel or black-painted steel bracket on the truck will likely be impacted also, like on this member's truck.
    Since the frame looks f'n amazing on that truck, I would be focusing my personal attention on everything in the last chunk of text I sent, and if I'm not getting a PPI, I've be bringing my own scanner to see last time codes were cleared (that does get logged in the ECU), testing 4WD, confirming operation of the A/C, confirming every button works, looking for evidence of aftermarket alarm and/or wire splicing under the hood and in the driver kick panel, etc.
    Black Wolf and Kraken[OP] like this.
  8. Oct 7, 2023 at 10:50 AM
    Kraken
    Paul
    I also think it's dumb to buy a truck just to have a truck. I usually get by just fine with my Versa. The four times I've needed a truck in the last 5+ years, I've been able to borrow one. We are planning on moving out to Oregon next year and living semi off grid, so now I actually have need for one.
    Yeah PPI definitely. I'm going to ask the guy to meet me at a Toyota service center to have the truck looked at before I test drive it. Hopefully he either did all the work to get it going good when he bought it, or he didn't and the last year of driving it f'ed it up enough for Toyota to fail it. Good call on the rust under the flairs, I should be able to feel that on the inside of the wheel wells right?
    I've been thinking about getting my own scanner just in case I run into an issue in the future. Are there any nice ones that aren't too expensive? I've heard some good things about BlueDriver, but mostly on review sites I haven't heard much directly from people.
    shifty`[QUOTED] likes this.
  9. Oct 7, 2023 at 10:57 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Looks like a good deal from here. Appears to have new(er) exhaust too, maybe they took care of other stuff (suspension, etc.) when the frame was done.
    Follow @shifty`s advice and you’ll probably be good.
    For how clean it appears and having a relatively new frame if everything else pretty much checks out I think that’s a good deal.
  10. Oct 7, 2023 at 1:26 PM
    Possibly.
    I bought the OBDLink MX+. It's not inexpensive, I think I paid around $100 for it? But it works across mutliple vehicles and is basically a "power" tool, it comes with lots of programmatic add-ons if used with their (free!) smartphone app. Their tech support is personalized, fast and awesome too.
    Others are using Bluedriver stuff, I've seen. It definitely seemed more finicky to me, and more catered towards Android users. I'm a forced-iOS user thanks to my job. And that ultimately landed me with OBDLink.
  11. Oct 7, 2023 at 1:45 PM
    Kraken
    Paul
    Might have to get the OBDLink. I use androids, but it looks like OBDLink has some more features than BlueDriver. Thanks!
  12. Oct 7, 2023 at 1:58 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Potentially sludge. Unless the owners changed the oil based on time and not mileage
