Single Scratch from Sniper Branch
Discussion in 'Detailing' started by nasher75, Sep 27, 2023.
  1. Sep 27, 2023 at 5:42 PM
    nasher75
    nasher75 [OP] New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I have a single scratch the entire length of my truck from a sniper branch in low afternoon light.
    I don't trust myself using a machine polisher and wondering if you think I can work this out by hand without over working the surface. I'd hate to leave a broad strip across the truck of hazy paint just to remove a trail stripe that's difficult to see unless you're looking for it.
    Scratch is in middle of pic and if you zoom in, you can see it was skipping across the surface in some spots so shouldn't be super deep.
    What do you suggest I try for hand applied product, or is that a waste of time?
  2. Sep 27, 2023 at 5:47 PM
    Use a random orbital polisher, you can't make it worse.
    nasher75[OP] likes this.
  3. Sep 27, 2023 at 5:49 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Erik, I have different size orbital buffers you cannot burn the paint or hurt it. You should pick one up thru Griot’s. It would probably take it right out if the scratch is not deep. Hope this helps. I also have one of the old fashioned dewalt’s that’s not orbital which will burn right thru the paint. Lol. Use to use that long time ago that one. Lol.
  4. Sep 27, 2023 at 5:56 PM
    That'll buff. Maybe even by hand with a light polish.
  5. Sep 27, 2023 at 6:04 PM
    nasher75
    Erik
    Los Gatos, CA
    Thanks guys. I've never used any machines in the past, but I'm willing to give it a try. It's really hard to see this scratch, but I know it's there, LOL. What product would you suggest with the orbital buffer. I'm assuming I need some kind of polishing compound?
  6. Sep 28, 2023 at 1:27 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    How deep is the scratch? Can you,feel it if you run a finger nail over it?
    by hand I’d try meguiars scratch x. If that doesn’t work……
    machine polish I’d use a random orbital (harbour freight) and polish of your choice.
    If that doesn’t work (I’d be surprised if you weren’t happy with the results) ……
    if it’s a deeper scratch try this:
    https://youtu.be/2nYF46P7B2c?si=Ad-DGl7Q0cFYOVpB
    bulldog93 and nasher75[OP] like this.
  7. Sep 28, 2023 at 1:53 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    :itllbuffout:
    bulldog93 likes this.
  8. Sep 28, 2023 at 2:15 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    If you can't catch your finger nail on it, it should buff out. Griot's Complete Compound, and a DA polisher should do it, at least that's what I would use.
  9. Sep 28, 2023 at 8:09 PM
    nasher75
    Erik
    Los Gatos, CA
  10. Sep 28, 2023 at 8:39 PM
    Oldandfat
    Cannuckastan
    really can’t argue that.
  11. Sep 30, 2023 at 4:45 AM
    briarpatch
    briarpatch New Member
    Least aggressive first....polish with a light polishing pad and check your results. Step up to a compound if necessary. Keep in mind...no one actually 'fixes' a scratch....you have to remove clearcoat to correct the problem.
  12. Sep 30, 2023 at 5:22 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Yup^^^^
  13. Sep 30, 2023 at 8:46 AM
    nasher75
    Erik
    Los Gatos, CA
    Thanks for all the replies. I'm going to start by hand first with lightest cut product.
    I know someone on here mentioned that I can't make it worse, but I see so many situations where someone buffed by hand or machine in an area going after a scratch or defect and just add swirls and haziness in the general area.
    I have some cleaner wax from Meguiars I'll start with that and go up from there. I think I also have an old bottle of TWS Fine Cut and some various polish and rubbing compounds. Will probably stay away from rubbing compounds
    Appreciate all the input.
  14. Oct 6, 2023 at 4:41 PM
    nasher75
    Erik
    Los Gatos, CA
    Circling back as it's so annoying when there is no resolution to a thread.
    I was able to remove the scratch along the entire truck using Meguiars Scratch X by hand with a foam wax applicator and microfiber towels. Some spots took 3-4 applications to get it all out. It's also funny how lighting works with Lunar Rock. I kept losing where the next section of scratch was and ultimately could only find it when the sun was at the right angle. Even a flashlight wouldn't help, lol
    Anyways thanks for all the tips and suggestions and now off to start a new thread with another detailing related question
    Durobumps and RusPro21 like this.
  15. Oct 6, 2023 at 6:38 PM
    Oldandfat
    Cannuckastan
    Glad you were able to get the scratch out!
  16. Oct 7, 2023 at 5:31 AM
    briarpatch
    Outstanding
    nasher75[QUOTED][OP] likes this.
