14” Display Scratches
Discussion in '3rd Gen Tundras (2022+)' started by HBV2017, Jan 29, 2022.
  1. Jan 29, 2022 at 7:02 AM
    HBV2017
    HBV2017 [OP] New Member
    Just wanted to post some quick anecdotal info. The 14” display in the Tundra seems to scratch much easier than the one in my 2020 Tundra, as well as the displays in my Infiniti. I’m assuming most of the scratches are in the anti-glare coating, however, I already have two small deep scratches that I can catch my fingernail on, with only 1700 miles on the truck (Have never had this issue before).
    I found a protector kit for the screen and dash gauges that I just ordered from ScreenProTech and will report back after install. It’s supposed to help hide most scratches as it is applied in a similar fashion to window tint.
  2. Jan 29, 2022 at 7:31 AM
    maverick129
    maverick129 New Member
    2022 Gray Tundra Limited
    I am seeing a lot of tiny scratches when the sun hits mine.
  3. Jan 29, 2022 at 7:39 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    How did you make a big scratch in the screen? Also mine came with a protective layer on it similar to smart phone screens have. Yours probably does as well. Should be able to peel that off and replace it. Not sure if your dealer can get the screen protectors yet.
    White3actual likes this.
  4. Jan 29, 2022 at 8:02 AM
    HBV2017
    My wife made the scratch (-.-).
    Just checked and there does not appear to be any film on the display.
  5. Jan 29, 2022 at 8:33 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Let her know she's banned to the backseat for 1-week (7 riding cycles). Animals and buddies only in the passenger.
  6. Jan 29, 2022 at 8:40 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  7. Jan 29, 2022 at 9:04 AM
    Toyota1234
    Jack
    Woh man that will get you kicked off this forum lol jokes not allowed
  8. Jan 29, 2022 at 9:22 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :anonymous: anonymous, I am safe.
    Toyota1234 and Rwaters like this.
  9. Jan 29, 2022 at 3:22 PM
    xc_tc
    xc_tc New Member
    Next time have her ask Toyota voice assistant to change the XM station.
  10. Sep 28, 2023 at 7:25 PM
    CitySlicker1794
    CitySlicker1794 New Member
    I found a sapphire glass kit that is crystal clear. The protector actually makes the screen appear much clearer than the factory film provided. The only issue I have seen is that the glass tends to bubble in a corner. The bubble is not apparent when the screen is lit up. The kit comes with the option of requesting a complementary replacement.
    Details
    BrandSKTU
    Compatible Devices2022 2023 2024 Tundra
    MaterialTempered Glass
    Item Hardness9H
    Compatible Phone Models2022 2023 2024 Tundra Limited/Platinum/1794 Edition/TRD Pro/Capstone 14 Inch
    Special FeatureTouch Sensitive, Oil Resistant, Anti-Fingerprint, 9 H Surface Hardness, Scratch Resistant
    Finish TypeGlossy
    Unit Count1 Count
    Screen Size14 Inches
    Screen Surface
    Cova_84 and minium like this.
  11. Oct 1, 2023 at 8:03 PM
    Cova_84
    Cova_84 New Member
    Stephen
    Southern California
    2024 Terra Tundra TRD Pro
    Nitto Recon Grappler LT295/70/17 Taco Vinyl Heritage front grill vinyl Tint 50% windshield 15% all other windows. BAKFlip MX4 Bed Cover
    I was about to recommend this! Very easy and clean install. I like it and it doesn’t take away from the quality of the screen.
    Gray Hawk and Tundrastruck91 like this.
  12. Oct 5, 2023 at 9:53 PM
    Chilibean
    Chilibean New Member
    2023 1794 Crew 6.5
    Pick at the corner…there is a factory piece of plastic covering the screen.
    Same happen to me. Didn’t understand how and why so easy. Laughed at myself when I got the factory plastic off. They did a good job getting it on there that’s for sure.
    Wood-Dro likes this.
  13. Oct 6, 2023 at 9:03 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    The factory screen covering should be removed as part of the dealership's pre-delivery checklist. It's used to protect the screen during manufacturing and shipping.
  14. Oct 6, 2023 at 9:57 AM
    Chilibean
    2023 1794 Crew 6.5
    Definitely was not removed on mine…and was applied well. Very hard to tell it was still there. Couldnt fathom why it scratched so easy.
    the4rdan likes this.
  15. Oct 6, 2023 at 10:41 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Anyone know where to find the speedo protection lens.
  16. Oct 6, 2023 at 9:11 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    Blufin[QUOTED] likes this.
  17. Oct 7, 2023 at 2:41 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Thank you kindly Sir.
    Chugbug likes this.
  18. Oct 7, 2023 at 9:12 AM
    40man
    40man New Member
    Glad the factory cover was still on mine. Made install of the Spigen glass cover easy as there was no dust removal or cleaning needed.
    White3actual and Blufin like this.
  19. Oct 7, 2023 at 7:08 PM
    Chugbug
    Chugbug New Member
    Anytime!
  20. Oct 8, 2023 at 12:51 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    How are you liking the Spigen glass cover? I’ve used their cases on my last 3 iPhones. Great products. Notice any reduction in touch screen performance?
  21. Oct 8, 2023 at 3:36 PM
    40man
    40man New Member
    It is excellent. Touch screen works fine. I put it on shortly after getting the truck, so I would have a hard time comparing touch performance, but touch is great. Less glare with it installed as well.
    Tundrastruck91 likes this.
  22. Oct 8, 2023 at 5:58 PM
    PNW Tundra Mike
    Back in So Cal
    Thanks!! I’m ordering
    40man[QUOTED] likes this.
  23. Oct 9, 2023 at 12:06 PM
    Gray Hawk
    Gray Hawk New Member
    Cincinnati, Ohio
    2023 toyota tundra 4x4 1794 edition smoked mesquite
    Tonneau cover; dash cam
    just ordered this one a few days ago. Thanks! I followed the directions except for the sticky pad part. It was pulling up the OEM screen but all is well. I had one small air bubble but waited two days and it disappeared completely. Looks great and touch sensitivity is very good. I am pleased! Thanks again!!!!
  24. Oct 9, 2023 at 3:56 PM
    JeffC1
    JeffC1 1794 Army Green
    Jeffrey
    NC
    2023 1794 edition TRD option Army Green
    Do you have a link to order the tempered glass for the 14" Nav on a 23 Tundra? Thank you
  25. Oct 10, 2023 at 9:02 PM
    CitySlicker1794
    Here is the Link:
    https://us.amazon.com/dp/B09WYNLXKG...p_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM
    Let me know if you get it installed without a bubble under the glass. I had an issue with one in the corner. Its only noticeable when the display is off when you first get in the truck during the day. Once I start the truck, I don't notice it.
    JeffC1 likes this.
  26. Oct 11, 2023 at 8:16 AM
    JeffC1
    Jeffrey
    NC
    Thank you
    I started going through threads again and see discussion of a factory cover. What is the factory cover made out of? I think my had an additional protection screen added by Toyota package. Called PR100. I’ll upload a pic of that on sticker. Now I see mine says tempered glass, so maybe I don’t even need something more??
  27. Oct 11, 2023 at 11:40 PM
    PNW Tundra Mike
    Back in So Cal
    Interesting. Looks like you’re covered!! lol. Gotta check my sticker now.
    JeffC1[QUOTED] likes this.
  28. Oct 13, 2023 at 5:31 AM
    JeffC1
    Jeffrey
    NC
    Agreed but very hard to tell if something is on there or not. I'd like to see a screen that doesn't have one to compare to.
  29. Oct 16, 2023 at 5:36 AM
    nodak67
    nodak67 New Member
    JR
    SET and that toyoguard pricing. they pretty much list all the toyota care default service that is free and add that last line for $699
  30. Oct 16, 2023 at 9:18 AM
    JeffC1
    Jeffrey
    NC
    I hear ya, about 1,000$ of stuff I would not have even considered of adding on if I had custom ordered. Toyota is smart by doing allocation to shove this extra stuff on us but we do have a choice.
