New Member with a 21 (Fire Extinguisher)
Discussion in 'New Member Introductions' started by Barold13, Apr 26, 2023.
  1. Apr 26, 2023 at 6:36 PM
    Barold13
    Barold13 [OP] New Member
    2021 Cement Tundra
    New to the group, I’m in South Carolina. Just wondering where everyone is mounting their fire extinguisher. I’m trying to stock my truck with essentials and I feel an extinguisher is definitely needed.
    Tripleconpanna likes this.
  2. Apr 26, 2023 at 7:00 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    In the back seat, where I can get it quickly if I ever need to.
  3. Apr 26, 2023 at 8:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Some mount under the front seat, some in the bed. I guess it depends on where you think will be closest to where you might need it.
    NewImprovedRon and texasrho83 like this.
  4. Apr 26, 2023 at 8:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Check out this thread.
    Here is mine:
  5. Apr 26, 2023 at 11:47 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Welcome...
    Element E50s are pretty popular w/a lot of folks; their compact size allows numerous mounting options
    https://youtu.be/GwzZJInS40g
    Sierradevil, 1lowlife and AverageJoe like this.
  6. Apr 28, 2023 at 3:26 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Welcome from So Cal
  7. Apr 28, 2023 at 4:44 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Welcome! I used a Bracketeer to mount a Element 50 under my driver seat.
  8. Apr 28, 2023 at 7:29 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    +1..
    My mount certainly isn't the quickest access, but I can't stand stuff being in front of my seat on the floor..
    p0wnukxr_eb7c05747a09556f58e0ee286676551b3f65b9f9.jpg pag2gqy5_f43891c8a459921f471a768a3fef978db646c84c.jpg
  9. Apr 28, 2023 at 7:45 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    +1 for @texasrho83 . DesertDoesIt seat jackers + mounting bracket.
  10. Apr 28, 2023 at 7:47 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC. In the storage compartment under my back seat.
  11. Apr 28, 2023 at 7:50 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    I've read and watched bad reviews for the element products. That's why I went with a standard ABC dry chem. Edit: Probably works ok, but when I need it I don't want to find out I screwed up.
    Tripleconpanna, DZ_ and texasrho83 like this.
  12. Apr 28, 2023 at 8:21 AM
    Welcome from NY.
  13. Apr 28, 2023 at 10:28 AM
    biebs96
    PA
    They fit in the rear door cup holders very nicely.
  14. Apr 28, 2023 at 10:54 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Mounted mine in my bed with a quick release for easy access:
  15. Apr 28, 2023 at 11:07 AM
    biebs96
    PA
    Ahh… I knew I had a photo of it somewhere..
    OHwendTrd and Tripleconpanna like this.
  16. Oct 6, 2023 at 4:16 PM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Do you recall which fire extinguisher that is? That is exactly what I want to do!
    biebs96[QUOTED] likes this.
  17. Oct 6, 2023 at 5:16 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Damie Street[QUOTED] likes this.
  18. Oct 6, 2023 at 5:42 PM
    biebs96
    PA
  19. Oct 6, 2023 at 6:47 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Same here... looks like it might even be the same quick release mount.
  20. Oct 7, 2023 at 10:41 AM
    Damie Street
    Edsel
