  1. Oct 6, 2023 at 11:17 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I did the same thing and had mine powder coated, but no top plates for me. I was warned that it would get damaged in shipping, etc.. But, they did a great job wrapping and packing them, and the PC seems to have been done very well :thumbsup:
    Are their top plates being shipped out welded onto the slider, or do you install the plates after mounting them up?
    bulldog93 likes this.
  2. Oct 6, 2023 at 1:30 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Pulled in to buy groceries and I parked far away and a little on one side of the line to ensure extra space next to me. I come out and this is what is taking up the last three spaces... ASSCLOWN BMW!!!
    Needless to say I parked my empty cart 1/4" from its driver's door. I put a little stick under the carriage so it didn't actually hit the car. But from where you would be walking out, it totally looks like the cart smashed into the car, and you wouldn't know what happened until you got all the way up to it. I didn't want to take a self incriminating pic, or be there too long for them to come back, but I was laughing all the way home.
    Velocity72, 1UP, Norfolk757 and 16 others like this.
  3. Oct 6, 2023 at 1:41 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
  4. Oct 6, 2023 at 3:16 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Little freshening up
  5. Oct 6, 2023 at 3:41 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Swapped out my old vault case with a roam case that has a solar panel mounted on top of it. This panel takes the place of the panel that was on my bed rack but was removed. Also, in case anyone is looking at the 83L vault case, it does fit a hot water heater. You just need to line up the control knobs with the indents in the case. Tight fit CD4C57B9-1346-4E71-8699-ECF1C6779DCB.jpg C07E45E6-17B0-404A-B47B-950CACE27DD7.jpg 4E1F3D98-5774-45D6-897A-454CB6483C3E.jpg EEF42915-E8CD-4284-BC1F-23B751E62F06.jpg AC405119-CA9C-4981-A8C1-F8D49F712CCA.jpg
  6. Oct 6, 2023 at 4:27 PM
    Vizsla
    Vizsla 2 = 2.5
    Did some of that today also.
  7. Oct 6, 2023 at 4:30 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    What do you both use to clean all that up? Looks great!
  8. Oct 6, 2023 at 4:34 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Right, I second that.
  9. Oct 6, 2023 at 4:48 PM
    Vizsla
    Vizsla 2 = 2.5
    Simple Green and generous application of Ace Hardware satin black spray paint for me.
  10. Oct 6, 2023 at 4:59 PM
    RustyShackle323
    Stewart
    NC
    Wise choice. Simple green is good stuff. I too use that as well, just haven’t used the spray paint.
  11. Oct 6, 2023 at 5:25 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Natural degreaser here then some scuffing and some steel it. Also restickerd the resi’s. I was also cutting out a bunch of crap lol
  12. Oct 6, 2023 at 5:36 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    What's the difference between BMW's and Porcupines?
  13. Oct 6, 2023 at 5:39 PM
    Tripleconpanna
    Pricks are on the3 outside of the porcupine :thumbsup:
  14. Oct 6, 2023 at 7:52 PM
    Whole EnchiTUNDRA
    Whole EnchiTUNDRA New Member
    2015 SR5 Crew Max
    IMG_6727.jpg IMG_1664.jpg IMG_7111.jpg Took the Tundra over to spend the week in Sedona with the family. Son brought his 4Runner and we ran Broken Arrow, Soldiers Pass, Outlaw and Diamondback trails. Shuttled my trail running son-in-laws to a few trail heads. Bumped the steps a few times and drug the trailer hitch twice but no real damage. Had a blast.
  15. Oct 6, 2023 at 8:09 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    How those new bolts doing? I think I see some 12points there. They look sweet
  16. Oct 6, 2023 at 9:12 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    It's always good to see the OG SOB bumper! Looks like a good time.
  17. Oct 7, 2023 at 7:47 AM
    coTony
    Tony
    Montrose, CO
    So you just pulled all the plastic out from the fenders wells. I guess I will do the same since I cannot find anything to actually keep the crap out of the small nooks and crannies.
    Looking good my man!!
    HulkSmurf14 likes this.
  18. Oct 7, 2023 at 8:09 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Can't you both contact ARC and see if they can help you? There are many options they offer when ordering to get you close...easy install and it's nice keeping the heart/engine clean! I'm not remotely (pun intended) close to your setups, but man do they help on both form/ function.
    https://arksplashguards.com/
    kingpin3919 and coTony[QUOTED] like this.
  19. Oct 7, 2023 at 8:35 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Well I don’t have a liners because of the fiberglass. Issue you’ll run into if you do is the intake port for the airbox is exposed and unprotected which you’ll need solution for.
  20. Oct 7, 2023 at 9:01 AM
    coTony
    Tony
    Montrose, CO
    I bought these and the owner was there when I was looking at them with my 3.0 coilovers, secondary shocks and remote resi's there was a lot of cutting I would have to do to make it work and most of the material would be cut away and the resi's would have to be removed. It would end up being two separate pieces.
    HulkSmurf14[QUOTED] likes this.
  21. Oct 7, 2023 at 9:04 AM
    coTony
    Tony
    Montrose, CO
    Yep, if you remember I bought the stuff I needed but I have not quite got it installed. I will be installing when I pull the liners. I have them all cut up so it will come right out.
  22. Oct 7, 2023 at 9:13 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    I wasn’t sure when I ordered them and figured they would be attached. When I unwrapped the crate I discovered they were not attached and were in perfect condition. It will be nice to be able to run these without the tops plates if desired.
    RCI definitely wrapped and packed these well to protect the powder coat.
  23. Oct 7, 2023 at 9:22 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Yikes! If those brackets are for the crewmax, it’s sitting too low. The shorter brackets should allow you to mount it closer to the frame. Too much of a gap in my opinion. They must’ve sent you a bracket made for a different truck. Here is mine.
  24. Oct 7, 2023 at 11:16 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Cleaned up the engine bay...degreaser, rinse, then Son of a Gun to help keep the rubber/plastic from drying out. Not show quality, but pretty dang sparkly for close to 4 years and over 85k!PXL_20231007_181154334.jpg
  25. Oct 7, 2023 at 1:32 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Dude I like the clean engine bay.
    BUT,
    looking at the pic closer...
    This looks like exposed (+) wire!!!
    Please tell me it's not, and it's some kind of optical illusion!!!
    Otherwise, that's a fire waiting to happen.
  26. Oct 7, 2023 at 2:15 PM
    Thanks for the heads up!
    I don't *think* it is. That's added amp cable, a silver nylon braid over gray insulation. The braid looks to be fraying, but wire under it still insulated. Might be the black ziptie looks like end of the wrap and exposed after that? PXL_20231007_210917969.jpg Here's a close-up, let me know if I'm missing something...thanks!
  27. Oct 7, 2023 at 2:18 PM
    Droptarotter
    Droptarotter New Member
    2020 Tundra TRD Off Road, Double Cab
    Some of you guys have been really busy! All I did was install two convex mirrors on my truck.
    Cheers
  28. Oct 7, 2023 at 2:49 PM
    It looks fine to me. I don't see anything. :thumbsup:
  29. Oct 7, 2023 at 3:29 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    The issue is clearance with travel. I had some custom ones done and no dice
  30. Oct 7, 2023 at 3:43 PM
    donWeb
    donWeb New Member
    Tony
    2018 SR5 DC 5.7
    You are correct @Quicksand_Tundra. Installed the correct brackets and the steps are now ‘high and tight’.
    btw- love the quicksand color.
