  1. Oct 5, 2023 at 8:22 AM
    coTony
    Tony
    Montrose, CO
    Do you have a part #?
    AggiePhil likes this.
  2. Oct 5, 2023 at 8:44 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Rig looks damn good!
  3. Oct 5, 2023 at 8:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nothing exciting here just preventative damage items done. Wrapped the abs lines and power steering lines.
  4. Oct 5, 2023 at 8:54 AM
    coTony
    Tony
    Montrose, CO
    What did you wrap them with for protection?
  5. Oct 5, 2023 at 9:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The power steering line I wrapped in rubber hose where it was closer to the body like a sleeve. Then the abs line thicker oem style plastic wire sleeving.
  6. Oct 5, 2023 at 9:12 AM
    luxury4play
    luxury4play New Member
    85532-08040 I have a friend at the local dealer who was able to get it for $54. I have an extra one if interested in it, I can modify it for you, so you can just plug it in when you get it.
  7. Oct 5, 2023 at 9:25 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    He's got a 2018, so unless he swapped out that panel to the 2020-2021 version it won't work anyway.
    Tundra-XP likes this.
  8. Oct 5, 2023 at 11:33 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    My RCI sliders arrived this morning. Hopefully I can get them installed sometime next week. Lead time was 6-8 weeks at time of order and they were done in 5.
  9. Oct 5, 2023 at 2:30 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Installed the Meso extended fuse cover under the dash. Turned out well.
  10. Oct 5, 2023 at 4:00 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    I've been having issues with my remote start. Sometimes it works sometimes it doesn't. I put new batteries in the key fobs and the same thing....
    Went to YouTube and found this video.
    (81) Common Remote Start Problems and Fixes - YouTube
    Based on what he said, I made sure all the doors were closed and checked the hood...blah blah... everything was good to go.
    Then I decided to check the battery and it was from December of 2017. So I figured it was time to replace it and did a couple of searches here...
    (81) Which Car Battery is Best? Let's find out! - YouTube
    There is no Costco nearby, so I ended up going to Walmart and getting the EverStart battery. (750 CCA; 925 CA)
    It would appear to have fixed the problem. Truck started right up with the remote. I waited awhile, tried it again and still worked just fine.
    Henry1jg and AggiePhil like this.
  11. Oct 5, 2023 at 5:21 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My neighbor (lovely 86 y.o. woman) wants to sell her 38k miles 2021 F-250 w/ plow. She's asking 40k. Anyone interested? I see this truck mostly sitting idle since her son passed away about a year/year and a half ago. Boston metrowest area.
    Meanwhile I checked how Raptor-coated skid plates are doing on my Tundra, and they are doing great! ;)
    Tundrastruck91 likes this.
  12. Oct 5, 2023 at 5:23 PM
    centex
    centex New Member
    Crew cab? 4x4? Diesel?
  13. Oct 5, 2023 at 5:27 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    FX4. Suicide doors - that's a smaller cab? Gas, I think.
  14. Oct 5, 2023 at 5:43 PM
    daveeasa
  15. Oct 5, 2023 at 5:48 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No idea. Looking at my 2019 Tundra, I guess there's some frame rust on 2021 Ford, but nothing major.
  16. Oct 5, 2023 at 6:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Awesome
    I need to see about the connector info- might be able to just swap the connector and not modify anything…
  17. Oct 5, 2023 at 6:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    That part number pulls as a single USB-A + single USB-C rather than the dual USB-C in your pictures…
  18. Oct 5, 2023 at 6:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I love that mod
    bulldog93[QUOTED] and coTony like this.
  19. Oct 5, 2023 at 6:15 PM
    RobertD
    Robert
    DFW, Texas
    I need to do this... I just have the fuse cover in the center console.
  20. Oct 5, 2023 at 9:28 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Looks like the dual USB-C is part 85532-0E110
    I’ve got one inbound to try this out!
  21. Oct 5, 2023 at 10:08 PM
    donWeb
    donWeb New Member
    Tony
    2018 SR5 DC 5.7
    First item on the list - Go Rhino Dominator D6 Steps.
    Installed only to find that the mounting brackets were wrong. Go Rhino quickly sent replacements.
    (Apparently, CM brackets are inches longer than DC)
  22. Oct 5, 2023 at 10:17 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Daaaaamn!!!!
    That looks sharp AF :bowdown:
    If you don't mind me asking, what did ceramic coating from them end up setting you back on the Tundra??
    nasher75 and coTony[QUOTED] like this.
  23. Oct 5, 2023 at 10:27 PM
    Tripleconpanna
    Nice!!!
    How did you end up configuring yours???
  24. Oct 6, 2023 at 3:00 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Nice have the same boards in my truck!
  25. Oct 6, 2023 at 6:34 AM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Put a couple nets on the ceiling of my shell for storage of all kinds of crap. I love it when everything has a place
  26. Oct 6, 2023 at 6:50 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Couldn't stand waiting 5K for next oil change...new Fumoto drain valve installed! Halfway between 1/8 and 1/4 turn past handtight indexed it perfect! PXL_20231006_133455931.jpg
  27. Oct 6, 2023 at 6:53 AM
    coTony
    Tony
    Montrose, CO
    They have sales here and there but they just had "THE" sale of all of their sales to celebrate their Anniversary. You can check them out here
    https://bobmosesmesa.com/
    I just went back for my 6 month check up and they got all but one scratch out and set me free to do it again!
    rdiddy5 and bulldog93 like this.
  28. Oct 6, 2023 at 10:32 AM
    Bergy24
    Bergy24 New Member
    What skid plate do you have that covers the drain pan?
  29. Oct 6, 2023 at 10:36 AM
    This one's From Talon's Garage. I got replacement front, then trans and cats.
    BlueRibbon4x4, bulldog93 and Bergy24 like this.
  30. Oct 6, 2023 at 10:45 AM
    roughfisher
    JP
    Northern Minnesota
    I got mine powdercoated with the top tread plate. Was initially going to order them raw and paint them myself but figured having the frame mounts powdercoated might be more durable and salt/corrosion resistant than what I could do.
