[Solved]Driver side bank sounds like a plunger/thumping
Discussion in '1st Gen Tundras (2000-2006)' started by Zach_795, Oct 2, 2023.
  1. Oct 2, 2023 at 4:24 AM
    Zach_795
    Zach_795 [OP] Master Apprentice
    Virginia
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k Clear front turn signals, tailights, third brake cover
    This morning I started the truck, drove to the gas station and all was well. As soon as I put it in park at the pump it started making a low pitched thumping noise that almost sounded like a plunger going up and down at rpm speed (on the driver side bank). I left it running when I went inside to get my sandwich and it was still doing it. I drove the remaining 14 miles to work and it did it all the way there. When I was coming down hill off the gas coasting it got much quieter. When I got to work I parked it and turned it off while I waited for the boss to arrive and open the gate. After letting it sit for a minute and restarting the noise was gone, but it slowly got back to its original volume as I drove around back. It really almost sounds like a plunger moving up and down at rpm speed, not metal to metal, and it’s definitely different than the high pitch tick cam noise that’s always present. Gonna post the video after this because it’s too big to attach. Please help I have no idea.
  2. Oct 2, 2023 at 4:40 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  3. Oct 2, 2023 at 4:44 AM
    Zach_795
    Virginia
  4. Oct 2, 2023 at 5:40 AM
  5. Oct 2, 2023 at 4:54 PM
    Zach_795
    Virginia
    Update: Started truck to go home from work and it sounded normal as usual. Got about halfway down the road and a CEL popped up. So I stopped at the next gas station and checked it with my scanner I keep in the toolbox. P0155 bank 2 sensor 1, the noise also started again about this time as I was cruising 60mph. I’ve had the code for this sensor before and I replaced it but there was no noise and the light went away right after. I kinda checked the vacuum hoses like shifty said and they all seem ok, I don’t feel any exhaust leak putting my hand around the manifold. After sitting at the gas station and checking it I started back up and the noise was gone but came back within a minute of idling. I also cleared the code and it came back as soon as I pulled out of the lot. It changes with rpm but not exactly like an exhaust leak would. Coasting and medium throttle seem to quiet it down. Still not a metal to metal sound.
  6. Oct 2, 2023 at 5:00 PM
    It sounds like a sucking noise to me. Like, loose spark plug, vacuum leak, hose to the intake manifold detached, hose between booster and manifold. Maybe the camera is distorting the sound.
    If you choose to replace the O2 sensor, replace both sensors on that bank. Only use Denso sensors for the replacement, and DO NOT buy them on scAmazon/fleaBay.
  7. Oct 2, 2023 at 5:01 PM
  8. Oct 2, 2023 at 5:01 PM
    Zach_795
    Virginia
  9. Oct 2, 2023 at 5:03 PM
    It's literally the same f'n connector from the other thread I just linked, dude. :rofl:
    And your hose is dry/cracked, you need to cut it back.
  10. Oct 2, 2023 at 5:05 PM
    This is the connector that's off. And I circled the crack. And this may be what's causing your P0155, so run for another 40-50 miles after disconnecting the neg batt cable for 10 minutes to clear out everything. This hose is disconnected but you don't see it until you're standing over it.
  11. Oct 2, 2023 at 5:07 PM
    It almost looks like the bib is cracked off?
    TX-TRD1stGEN likes this.
  12. Oct 2, 2023 at 5:10 PM
    And here's another shot from the last second of your 1st video. Just in case you're not convinced :rofl:
    FirstGenVol, KNABORES and w666 like this.
  13. Oct 2, 2023 at 5:55 PM
    bfunke
    bfunke Tundra Curmudgeon
    I had several dry and cracked engine hoses. The stealership sells most of them but one of the hoses was like $70. Can’t really find them elsewhere. Would be nice if someone figured out OEM supplier and part numbers
  14. Oct 2, 2023 at 7:03 PM
    Zach_795
    Virginia
    You guys are awesome, thanks a bunch. Cut the dry end off, re-hooked up the hose and put a zip tie on it temporarily until I can go get some new hose tomorrow. Started up and both CEL and noise went away immediately. I don’t know how I didn’t see it dangling before. It was a hell of a noise to hear at 5:30 on Monday morning! :thumbsup:
  15. Oct 2, 2023 at 8:07 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I had that same hose pop off a few months back. Put back on with a zip tie as you did and good to go. I heard that it had fallen off before I got any codes though.
    KNABORES likes this.
  16. Oct 3, 2023 at 3:38 AM
    Zach_795
    Virginia
    Then it was the same as mine did, fell off on the way to work but the code didn’t pop until the way home.
  17. Oct 5, 2023 at 4:24 PM
    Zach_795
    Virginia
    New problem: All the vac leaks and dry rotted hoses were replaced. Replaced o2 sensor per P0155, have cleared the code 3-4 times and drove to work but it keeps coming back. Any suggestions?
  18. Oct 5, 2023 at 4:32 PM
    Which exact O2 sensor(s) did you replace, please list all locations?
    What brand of sensor did you buy?
    Where did you buy that sensor?
  19. Oct 5, 2023 at 5:14 PM
    Zach_795
    Virginia
    Replaced upstream driver side sensor with denso brand I bought at advance
  20. Oct 5, 2023 at 5:52 PM
    Weird, I couldn’t find Denso at Advance when I looked last but glad they got you one. Hopefully they keep carrying them, I’m sure I’ll lose another before too long!
    I see two mistakes though.
    p0155 is bank 2 sensor 1 (passenger upstream)
    its recommended (realistically) to replace upstream and downstream on the bank with a failure to avoid weird discrepancies with having one new and one old sensor.
    If www.densoautoparts.com parts finder shows the upstream sensor parts for your truck are the same, you could just swap the sensor you pulled into the passenger upstream. Some years used different parts between upstream or downstream depending on the bank, so you need to confirm.
  21. Oct 5, 2023 at 5:56 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    P0155 for an 02 is passenger side (bank 2) upstream.
  22. Oct 5, 2023 at 5:59 PM
    Seeing Bubba’s reply just reminded me also: What Denso part number did you get? Just want to confirm; I know they make a universal sensor, and an exact fit sensor for our trucks. I don’t know (without looking) if both are heated or not, and that code is referencing heat circuit failure. We should check your part number to confirm!
  23. Oct 5, 2023 at 6:49 PM
    Zach_795
    Virginia
    234-4169
  24. Oct 5, 2023 at 7:00 PM
    Good news is, Upstream are identical on the '02 Limited 4.7L and downstream for your 4WD are the same downstream on both banks also, it's the same part number except the last 4 digits are "-4162". I feel bad for the 2WD guys who have different downstream sensors bank-to-bank on your year/engine/trim!
    Hopefully you still have the old sensor, you didn't toss it or mangle it pulling it out? If so, slap it in the passenger side upstream slot and see if your code disappears.
  25. Oct 6, 2023 at 7:18 PM
    Zach_795
    Virginia
    Yep, y’all were right. Replaced the passenger side upstream after fighting the old one out for an hour. No codes after a 30 min drive. :)
    shifty` likes this.
  26. Oct 6, 2023 at 7:48 PM
    Sometimes readiness takes a couple of trips, so don’t count your chickens yet.
    and if the code changes to (p013x, I think?) or to cat efficiency, holler back. There’s a reason why, and it’ll make sense when explained. (It won’t actually be your cats)
