Paint , Ceramic coating
Discussion in 'Detailing' started by TundraWorkHorse, Sep 27, 2023.
  1. Sep 27, 2023 at 6:49 AM
    TundraWorkHorse
    TundraWorkHorse [OP] New Member
    2023 Toyota Tundra Platinum
    Getting paint chips . Was a long work trip to be honest but just wondering if the paint is unusually soft .
    Putting on some ceramic coating and the Toyota hood deflector anyway . Hope it helps .
  2. Sep 27, 2023 at 7:19 AM
    TundraRod5
    TundraRod5 New Member
    Rodney
    2023 Tundra TRD Sport Lunar Rock
    I did a clay bar treatment and then ceramic wax the entire truck with only 50 miles on it. Started with a Clean Slate foam wash to get all/if any previous waxes or coatings on the truck from the factory.
    Wow...What a difference now. Cant wait for the first time it sees rain to see how it repels. But first thoughts...Perfect.
    I also did a badge removal and went pretty hard on the paint with my nail until then using the wonder wheel. With some rubbing compound and polishing compound. Removed all small scratches or blemishes and is perfect now. Just a heads up.
    TundraWorkHorse[OP] likes this.
  3. Sep 27, 2023 at 7:20 AM
    brutalitybob
    brutalitybob New Member
    never go too hard on da paint ;)
  4. Sep 27, 2023 at 7:23 AM
    Tundraaa3
    Tundraaa3 New Member
    Ceramic won't save it from chipping. I still get them with my ceramic coat.
  5. Sep 27, 2023 at 7:32 AM
    pursuit2550
    pursuit2550 New Member
    Ceramic coating is too hyped up. It certainly will not protect against chips. Toyota does have a weak paint in my opinion. I have several chips in my hood. Ceramic coating helps to repel dirt, keeps it from sticking to the truck. When it's time to wash it, most of the dirt falls off with rinsing. But, you can and will damage your paint if you wash your truck the wrong way. That is why to me, unless you do it yourself, ceramic coating is too hyped up. If you do do it yourself just remember it's a coating not magical shield. I personally wouldn't pay the outrageous prices I have seen.
  6. Sep 27, 2023 at 7:37 AM
    TundraRod5
    Rodney
    Correct. It just helps with the maintenance of the truck down the road. Washing and cleaning is much easier. Drying as well. Could use air to dry which will help with the small swirls from drying.
    The only thing to protect from rock chips is a clean protector on high compact spots. Which that is obvious.
  7. Sep 27, 2023 at 7:43 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    PPF on the hood and quarter panels is your best bet. Hood deflectors not so much.
  8. Sep 27, 2023 at 3:21 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    PPF and where possible rock chip guard. Most ceramic wont do a thing for chips.
  9. Sep 27, 2023 at 4:01 PM
    White3actual
    White3actual Verbal Assault Specialist
    Near da beach....
    2023 SR5 crewmax 4x4
    A good ceramic coating will keep your vehicle looking great with the proper care. I have done my own coatings on my last 4 cars. Extremely time consuming (10-12hrs) but saved me $1,000 to $1,400 in labor cost for a 3+ year coating.
  10. Sep 27, 2023 at 4:33 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Ceramic coatings are pointless unless you hand wash.
    Saltyhero13 likes this.
  11. Oct 5, 2023 at 1:43 PM
    BassRunner
    BassRunner New Member
    Kenny
    Lexington. South Carolina
    2018 Limited
    Can u clay clear factory PPF
  12. Oct 5, 2023 at 3:25 PM
    Can u claybar PPF? Yes
    ToyoMafia likes this.
