Engine wash
Discussion in 'Detailing' started by Bdk437, Sep 11, 2023.
  1. Sep 11, 2023 at 4:11 PM
    Bdk437
    Bdk437 [OP] New Member
    Bruce
    2019 Tundra SR5 2wd Crew cab
    5000 series Bilstien shocks TRD sway bar
    I have a 2019 SR5 2wd crew.5.7
    My question is how safe is it to wash under the hood?
    Can I get anything wet not allowing it to run?
  2. Sep 11, 2023 at 4:16 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Not Tundra specific but I've seen a general recommendation to cover the alternator and fuse box, though I've seen demonstrations of folks dousing the alternator with full force of water and no issue.
  3. Sep 11, 2023 at 4:25 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Everything in there is designed to handle getting wet. When it's bad enough, I've rinsed it off with a garden hose.
    Just don't do the obvious: rinse it with your air intake open, don't use a pressure washer on the fuse box, etc.
    Gene_in_FL and Mr Badwrench like this.
  4. Sep 11, 2023 at 4:48 PM
    Bdk437
    Bruce
    Thanks to both!!
  5. Sep 11, 2023 at 5:58 PM
    2mchfun
    A trigger sprayer bottle with a simple green diluted solution, a variety of brushes, a good compressed air nozzle with gentle pressure, and about 4 cold brews will clean things up really well. Just take your time and reach in with different types of brushes to scrub. Then blow it down and out as you go.
    EmergencyMaximum and Bdk437[OP] like this.
  6. Sep 11, 2023 at 6:05 PM
    bfunke
    bfunke Tundra Curmudgeon
    Simple Green can harm some alloys. I wash it cold by spraying it with engine cleaner, sponging with soapy water and rinsing. Be careful not to spray directly into alternator and fuse box. Afterward I dry with leaf blower and drive it till engine is hot and dry.
  7. Sep 11, 2023 at 7:27 PM
    Saltyhero13
    I think this is very much the case and you'll be ok if those items get wet.
  8. Sep 11, 2023 at 7:33 PM
    Mr Badwrench
    Mr Badwrench New Member
    You can run a high pressure wand on it, but don't concentrate it. I mean DONT use a 4600 psi rig, but a DIY car wash is okay. Sweep back and forth quickly and know what you're spraying.
    Saltyhero13 likes this.
  9. Sep 11, 2023 at 8:05 PM
    737fixer
    737fixer New Member
    Do it all the time. Aluminum safe Simple green and garden hose couple times a year. Regular Simple Green is harmless but can discolor Al parts. Purely a personal feeling with zero facts to support it but a pressure washer would seem more likely to enter bad spots.
  10. Sep 12, 2023 at 4:13 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    If you can handle his tone of voice and overall delivery...........here's how to Get 'Er Done without the hose pipe as 2mchfun made mention above.
  11. Sep 12, 2023 at 4:31 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    When I wash out my engine bay with a garden hose, I have the engine running. I don't use any additional products, just water.
  12. Sep 12, 2023 at 6:24 AM
    Warreng
    Warreng New Member
    Get some mountain bike specific cleaner like muc off and use brushes like others have said. it works amazingly well and is very gentle on the sensitive bits.
    dondino likes this.
  13. Sep 27, 2023 at 3:36 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    you can buy the purple simple green. It doesn’t tarnish aluminum. I think it’s simple green HD
  14. Oct 5, 2023 at 4:25 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I use presoak at a car wash bay on low pressure and then rinse low pressure ...do it about once a year. Not perfectly clean but stays ahead of it.
  15. Oct 5, 2023 at 9:45 AM
    Bdk437
    Bruce
    Makes the most sense… thanks
  16. Oct 5, 2023 at 11:24 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    Yup - it's this stuff. Simple Green themselves say to use this instead of the green on aluminum.
  17. Oct 5, 2023 at 11:26 AM
    Oldandfat
    Cannuckastan
    yuppers, that’s it. I use it in an untlrasonic cleaner,to clean my carbs when they are gummed up. Works great, and won’t tarnish alloy
