Bigest tire that would fit 18" wheel with +18 offset
Discussion in '3rd Gen Tundras (2022+)' started by tgrasshopper, Oct 3, 2023.
  1. Oct 3, 2023 at 1:27 PM
    tgrasshopper
    tgrasshopper [OP] New Member
    Does any ome know what would be the bigest tire that fit on 2022 tundra trd offroad?
    For my winter tire on oem wheel i have 275/70r18 and I'd like to maybe get something biger for summer.
    My rims are 18inch with +18off set.
    Does the 295/70r18 fit witout modification? I dont feel like cuting or modifing the fender.
    I do go offroad with the truck once in a while.
    Any one did that setup? Send me picture :)
  2. Oct 3, 2023 at 2:06 PM
    tgrasshopper
    Just womdering. If it's close and for some reason the suspention would required to travel. Would that cause a rub/hit?
    I do not want a end up with a truck with big tire that can only drive in parking lot :)
    Far from been and expert in tire/suspention
  3. Oct 3, 2023 at 2:17 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    295/70 R18 with a slight rub on the mud flaps. Very same dimensions are on my rig.
    18” with an 18+ offset. Will have slight bit more rubbing when the suspension articulates.
    As a disclaimer, I have a 2/1 fake lift a la spacer kit. So YMMV
  4. Oct 3, 2023 at 2:51 PM
    Wood-Dro
    Wood-Dro New Member
    I have 295/70 R18 with +25 and I'm real close but no rubbing. No lift, but also no mud flaps on the Platinum. Yours at +18 will give you another .27".
    Hoody likes this.
  5. Oct 3, 2023 at 4:10 PM
    tgrasshopper
    Thanks evryone for the info. I'll rethink ehat I want a do. Sound like I need a lift if I want a out those 285/70r18 with +18 off set.
    Saw one with 35 and trd lift kit today. It look good. At Arond 7500$ canadien it's to mutch for me.
  6. Oct 3, 2023 at 4:32 PM
    Black widow TRD
    Manuel
    You can go up to 295/70R18. Just the articulation of the suspension. I think 285/70 R18 your safe, since you’ve got the TRD OR package.
    Eurodriver likes this.
  7. Oct 3, 2023 at 7:46 PM
    tgrasshopper
    Yeah, i think i'll concider that. Some how does not look like a polular size tire from hat I saw. I might just stick with 275/70r18. It's what I run in winter.
    Would kind a be smarter to stay on same size and get a proper matching spare tire.
  8. Oct 4, 2023 at 5:46 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    295/70/18 with +18 is a great fit with a level or a lift or stock, I’ve tried all three ways they all function dont be scared
