Noise when back window is down rattle and Clinging
Discussion in '3rd Gen Tundras (2022+)' started by Levo1228, Jul 24, 2022.
  1. Aug 17, 2022 at 9:31 AM
    Jdel427
    Jdel427 New Member
    Jeremy
    2022 Army Green Toyota Tundra 1794 Edition
    Also have the window rattle when down along with the clunking noise when going over bumps. Unacceptable for any new car. Also noticed when switching to 4H and cutting the wheel all the way the front tires get stuck and won’t move. Definitely disappointed.
  2. Aug 17, 2022 at 9:34 AM
    Craftty1982
    Craftty1982 New Member
    Rich
    The 4 wheel drive is like that on every 4 wheel drive vehicle. You lose turn radius while in 4wheel.
  3. Aug 17, 2022 at 9:35 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Um… are you trying to turn on a dry surface in 4wd??? If so cutting the wheel in 4wd on a non-slick surface is a big no no. The getting stuck and not moving while doing that is normal.
    Dfrink, DFS and Breathing Borla like this.
  4. Aug 17, 2022 at 9:35 AM
    Breathing Borla
    AZ
    hold on there a min, your talking 4hi on dry pavement cutting the wheel all the way?
    if so, DO NOT DO THAT. its a part time system not AWD, your going to break your truck man
    DFS likes this.
  5. Aug 17, 2022 at 9:43 AM
    Jdel427
    Jdel427 New Member
    Jeremy
    My previous 2 Rams never fully locked up on me to the point where I couldn’t move.
  6. Aug 17, 2022 at 9:45 AM
    Jdel427
    Jdel427 New Member
    Jeremy
    I must be mistaken as far as my old vehicles. Is 4lo different with the turn radius? Maybe I’m getting it confused. It was in error I even found out as the car wash accidentally put it into 4hi while cleaning the interior.
  7. Aug 17, 2022 at 9:49 AM
    trazerr
    trazerr New Member
    Oregon
    Were you in 4H or 4Auto with your Rams?
  8. Aug 17, 2022 at 9:49 AM
    Breathing Borla
    AZ
    ya man, do not drive in 4hi or 4 low on dry pavement, it really does need to be slippery out to use those systems. 4 lo you would only use off road and not on pavement at all.
    the only except is once a month going in a straight line is switch it to 4 hi for a few miles and switch it out before you turn, just to exercise the system.
  9. Aug 17, 2022 at 9:50 AM
    Breathing Borla
    AZ
    I had a ram too, you were probably in 4 wd auto, if you were just in 4 hi it would have been the same thing.
    4wd auto is nice, tundras do not have that
    Dfrink and Jdel427[QUOTED] like this.
  10. Aug 17, 2022 at 9:51 AM
    trazerr
    trazerr New Member
    Oregon
    Beat ya ;)
  11. Aug 17, 2022 at 9:51 AM
    Jdel427
    Jdel427 New Member
    Jeremy
    I must’ve been mistaken. I don’t think it was 4hi for the previous trucks.
    trazerr[QUOTED] likes this.
  12. Aug 17, 2022 at 10:01 AM
    Jdel427
    Jdel427 New Member
    Jeremy
    Thank you for the info! I’ll be sure to do that. So snow/ice on side streets, highways, etc. it’s best for 4hi not 4lo?
  13. Aug 17, 2022 at 10:05 AM
    Breathing Borla
    AZ
    4lo is for climbing really uneven ground or steep slippery grades (off-roading), if you use your truck around town, or decent gravel roads, 4HI is all you'll need. it has to be pretty slippery to use 4 hi like snow covered roads, then there is plenty of traction slip for the system to work right and you won't feel all that binding up.
    or boat ramps, I use mine for that as most are slicker than snot or wet and you'll one wheel wonder spin without it
    Jdel427[QUOTED] likes this.
  14. Aug 17, 2022 at 10:23 AM
    Jdel427
    Jdel427 New Member
    Jeremy
    Understood. Thanks again for the info. Much appreciated. Sorry to distract from this topic of the window rattle and clunking.
  15. Apr 17, 2023 at 4:39 PM
    B400f4.5
    B400f4.5 New Member
    2022 Crewmax 2WD
    Fixed rear window rattle!
    Took my 2022 Crewmax Limited in for the rear window rattle and regular service.
    Service guys found the rear window issue and said it was loose bed bolts. They re-tightened to factory specs and that fixed the issue! I'm so happy.
    arrampico likes this.
  16. Apr 18, 2023 at 6:51 PM
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    That’s it??? Wonder if I could just re-tighten mine at home….need torque specs
  17. Apr 18, 2023 at 7:07 PM
    B400f4.5
    B400f4.5 New Member
    2022 Crewmax 2WD
    Mechanic said the bed bolts were loose and he re-torqued them to 36 ft lbs. Then test drove the truck and no more window rattle. Hope it works on your truck.
    arrampico[QUOTED] likes this.
  18. Oct 4, 2023 at 9:03 AM
    24Tundee
    24Tundee New Member
    NorCal
    '24 Tundra Limited TRD OR
    Does anyone know the torx size bit for the bed bolts? Got the same issue.
  19. Oct 4, 2023 at 11:45 AM
    Hella Krusty
    Hella Krusty New Member
    Beer cans rolling around in the box??
