Wheel bearing change without press?
Discussion in '1st Gen Tundras (2000-2006)' started by MechEng13, Sep 28, 2023.
  1. Sep 28, 2023 at 8:32 AM
    MechEng13
    MechEng13 [OP] New Member
    2005 Tundra SR5 4WD
    I'm having trouble finding the thread I read previously while I'm on my phone.
    Is it reasonably possible to change my front bearings and hubs using my bearing swap kit (threaded rod various plates and spacers) on my 2005 Tundra?
    It has worked fine for all my FWD cars and all wheel drive SUV's.
    Please advise. My normal local shop doesn't like to do work on parts off the street. So I'm trying to avoid needing a press.
    Thanks
    Ross
  2. Sep 28, 2023 at 10:04 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    MechEng13[OP], Galladanb and shifty` like this.
  3. Sep 28, 2023 at 4:54 PM
    MechEng13
    2005 Tundra SR5 4WD
    I called my mechanic and asked again... He said he's too old to do that type of work, hahaha... Then gave me the name of another shop down the road that does good work. I called and the guy quoted me $125 if the spindles are off the truck.
    Problem solved.
    Thanks folks!
    Backslider and EmergencyMaximum like this.
  4. Sep 28, 2023 at 4:57 PM
    Where are you located? Need mine pressed too…..
    Jack McCarthy likes this.
  5. Sep 28, 2023 at 4:57 PM
    EmergencyMaximum
    Man, where do y'all find such bombastic deals, gang?
  6. Sep 28, 2023 at 5:01 PM
    MechEng13
    2005 Tundra SR5 4WD
    I just northwest of Pittsburgh PA
  7. Sep 28, 2023 at 5:17 PM
    Dang it. Maybe I’ll pack em in my suitcase, I’ll be in Pittsburgh Tuesday.
  8. Sep 29, 2023 at 11:05 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Bro, pencil me in. I'm losing money at this rate!
  9. Sep 30, 2023 at 2:04 AM
    Aerindel
    Aerindel New Member
    Montana
    A press is like $200 and handy for a lot of things, just saying.
    Backslider and tvpierce like this.
  10. Sep 30, 2023 at 4:24 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I use mine on average about once a month for something, but the other 353 days a year? Its just occupying valuble shop space. It ends up being a catch all for junk. The real trick is to convince a friend that they need one.
    If I had less space, or used it any less it would be one of the first things to go.
    FirstGenVol likes this.
  11. Sep 30, 2023 at 6:23 AM
    To be clear, you need a 50 ton press. Cheapest one I found at HF was $258 on sale. Not terrible, but I already have access to a 20 ton, not sure where to store another press.
  12. Oct 3, 2023 at 6:51 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    I used 20 ton press for mine. Don't think I'd want to do it without.
    KNABORES likes this.
  13. Oct 3, 2023 at 7:20 AM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4, 2012 Mini cooper clubman S
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    I also used a 20t press to do mine. It’s a fairly involved process. Had the race stick to the hub, so replaced those as well. IMG_4387.jpg
    KNABORES and FirstGenVol like this.
  14. Oct 3, 2023 at 8:23 AM
    These are encouraging posts. I will try with the 20 ton we have and only upgrade if it fails.
  15. Oct 3, 2023 at 8:34 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    remember that both heat and ice will help facilitate a much easier time pressing
  16. Oct 3, 2023 at 2:01 PM
    $125 is a good price. That's what I got charged per spindle on mine.
