Rear axle not seating all the way
Discussion in '1st Gen Tundras (2000-2006)' started by Cormorant, Oct 2, 2023.
  1. Oct 2, 2023 at 12:25 PM
    Cormorant
    Cormorant [OP] New Member
    06 Tundra V8 SR5
    IMG_20231002_150448895_HDR.jpg IMG_20231002_150433570_HDR.jpg I'm in the process of reinstalling both rear axles. The hub isn't meeting with the diff housing the way it was before removal though, and I've been left with a bit of a gap. I feel like this it probably something simple, maybe I don't have something lined up? I dunno but I'm having a derpy moment and hoping someone here might have an idea as to what I'm missing. I haven't tried forcing it on as I didn't have to before and I don't want to ding up any threads.
    I did just replace the backing plate and bearings but I really doubt that the bearings or retaining rings are the issue.
  2. Oct 2, 2023 at 12:32 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    KNABORES likes this.
  3. Oct 2, 2023 at 12:45 PM
    Cormorant
    06 Tundra V8 SR5
    It's about 3/16" on one side and almost a whole inch on the other. Both reach deep enough to engage the drive shaft. On visual inspection the splines look clean.
  4. Oct 2, 2023 at 1:07 PM
    Cormorant
    06 Tundra V8 SR5
  5. Oct 2, 2023 at 2:11 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If the splines are engaged (ie: you can spin the driveshaft by turning the axle) you might try tapping it in with a deadblow hammer.
  6. Oct 2, 2023 at 2:45 PM
    Cormorant
    06 Tundra V8 SR5
    Thanks for the tip. Your right, the splines are engaged, so maybe it could be small imperfections in the splines. After all its bypassed all the other potential hang ups if it made it that far, right?
    Both are pretty hard up but Ill give a hammer and a file a try.
