Pops' Build (Sachi) -Supercharged, LT Prelander
Discussion in '2.5 Gen Builds (2014-2021)' started by reywcms, Oct 2, 2023.
  1. Oct 2, 2023 at 11:18 AM
    reywcms
    reywcms [OP] New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Well I've been meaning to do this for awhile so here we go. Starting this build thread for the old mans rig. This has gone through a few iterations since we've started this journey like most things as you learn and adapt to use case. Initially, this build started life as a Stage 2+ from TAV. But since then we've added and changed a few things.
    The goal was an overlanding build and some Baja runs. Well since we've done this I've built a rig and now the needs of going a bit faster etc have slightly changed his build. We plan on potentially doing some Norra events and more Baja runs, Vegas to Reno etc but we will see. The truck is currently in the shop for a full revamp. I'm sure I forgot a few things. More to come!
    Initial build video link- https://www.youtube.com/watch?v=N2bOyJbAitE
    2018 Crewmax Tundra SR5 in White
    Grey Wrap
    Bumpers
    ADD Front Bumper (New bumper being built)
    Expedition One Rear Bumper (New bumper being built)
    Body
    McNeil fiberglass front fenders
    Seibon carbon vented carbon fiber hood
    Fiberwerx carbon fiber front fenders (Being installed)
    Suspension- Currently Changing
    Total Chaos Long travel front
    King 2.5 Coil overs with remote resi and adjusters (Acctuned)
    King 2.5 triple bypass and remote resi (Acctuned)
    RCV Axles
    Total Chaos rear long travel
    King 2.0 x12" Smoothie with remote resi and adjuster
    Custom Deaver leaf pack
    New Suspension Going In (in progress)
    Front LSK Race Kit
    RCV Axles
    Custom spec ADS front coil over 2.5x10" with remote resi and adjusters
    Custom spec ADS triple 3.0x10" triple bypass with remote resi and adjusters
    ADS Bump Stops
    Rear ADS 4.0x16" 5 tube bypass
    Custom deaver i96xhd leaf pack
    ADS Bump stops
    Spring under conversion
    Custom bed cage with enclosure paneling
    Full front and rear frame plating and trussing and engine cage,
    Custom roll cage (next round)
    Custom GFC frame tie in (in progress)
    Rear Bed Setup
    Decked drawer removed
    Custom dual spare/storage compartment panel (in progress)
    Dual AGM batteries (in progress)
    Custom Water meth/Washer tank combo box (in progress)
    Engine
    Previously Magnuson Supercharged
    Currently Whipple 2.9 with 3.50" 8psi
    DW 650cc injectors
    DW 340 fuel pump
    @snivilous custom throttle body adapter plate
    RCF throttle body
    Magnuson airbox with afe dry filter (Changing)
    Radium catch can
    AEM Water meth kit (in progress)
    Custom intake box (in progress)
    Wheels,Tires,Brakes
    Method 701 black 17"
    37 BFG Ko2 may switch to Baja Boss AT
    Alcon Big brake kit front and rear
    Comms
    Garmin Inreach
    Starlink mobile
    Rugged race radio hardwired
    Lighting
    @Baja Designs LP9 Pros- 2 white, 2 amber
    Baja Designs S1 Chase light
    Baja Designs Squadron pros in rear bumper
    Switches
    Previously Spod
    Currently Switch pro 9100
    Misc
    CFX 75 Dometic dual zone fridge removed as needed
    Viaair compressors
    Comeup winch
    Trailers
    Previously Turtle back expedition
    Currently Imperial Outdoors Roamer 1
    Camper Topper
    Previously GFC V1 with RTT
    Currently GFC V2 Topper Only
    Skid Plates
    RCI full skids
  2. Oct 2, 2023 at 11:37 AM
    coTony
    Tony
    Montrose, CO
    I thought this was your old man’s truck, did he go a different route?
    Mdl likes this.
  3. Oct 2, 2023 at 11:44 AM
    reywcms
    Rey
    North Plains,Oregon
    This is his truck. lol just making a build thread for it. Since he's not on here
    Florida AF, AZBoatHauler, Mdl and 2 others like this.
  4. Oct 2, 2023 at 1:04 PM
    coTony
    Tony
    Montrose, CO
    Ok, I seen you were making the build thread but I thought he had the MT’s in the all terrain version
  5. Oct 2, 2023 at 1:05 PM
    reywcms
    Rey
    North Plains,Oregon
    He first had Toyo MT's now on the Ko2 but may change to the Baja boss AT. He likes the fact the ko2 is a bit lighter.
    Mdl likes this.
  6. Oct 2, 2023 at 1:10 PM
    coTony
    Tony
    Montrose, CO
    Gotcha! I knew he changed but obviously I am behind. Very nice build!!
    Sunnier and reywcms[QUOTED][OP] like this.
  7. Oct 2, 2023 at 1:18 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Rey, can you snap a photo (or ask your dad to) of the blue sea holder on top of the battery. Is the starting battery still in that location when that engine bay pic was taken or are those just studs and batteries had already been relocated to the rear
    If it isn’t a custom part, a link would be much appreciated
    Sunnier, reywcms[OP] and FrenchToasty like this.
  8. Oct 2, 2023 at 1:23 PM
    reywcms
    Rey
    North Plains,Oregon
    Starter battery is in the stock location but moving to the rear. I think I have a pic let me see. The trucks at the shop so he can't snap one. Please hold
    Sunnier and Mater[QUOTED] like this.
  9. Oct 2, 2023 at 1:26 PM
    reywcms
    Rey
    North Plains,Oregon
    Mdl and Mater like this.
  10. Oct 2, 2023 at 1:37 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    :monocle:
    Looks like mounted to a plate with those hex’s and that plate is vhb’d to the battery?
    maybe?
    I like it!:thumbsup:
  11. Oct 2, 2023 at 1:41 PM
    reywcms
    Rey
    North Plains,Oregon
    Yes, does seem that way. This was on of the original install items from TAV. The secondary battery lived in the bed in a case but all this is changing.
    Fastlane47, n0rth, Mdl and 1 other person like this.
  12. Oct 10, 2023 at 3:30 PM
    reywcms
    Rey
    North Plains,Oregon
    Build Update 10/10/23
    Hover mode activated. The tear downs begun!
    Fastlane47, saybng, n0rth and 14 others like this.
  13. Oct 10, 2023 at 3:43 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Who's doing the work?
  14. Oct 10, 2023 at 3:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice setup! Looking good...
    reywcms[OP] likes this.
  15. Oct 10, 2023 at 5:24 PM
    reywcms
    Rey
    North Plains,Oregon
    SSbuilt in Phx
    coTony and Cruzer[QUOTED] like this.
  16. Oct 10, 2023 at 8:26 PM
    NWPirate
    Zach
    WA
    :headbang:
    reywcms[QUOTED][OP] likes this.
  17. Oct 10, 2023 at 9:40 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    So…who is getting his take offs?
  18. Oct 10, 2023 at 10:10 PM
    RobertD
    Robert
    DFW, Texas
    And here I thought my 6 ton jack stands felt beefy. That is just a mighty impressive photo! So few components left on the truck and its still just incredible to stare at :bowdown:
  19. Oct 11, 2023 at 6:48 AM
    reywcms
    Rey
    North Plains,Oregon
    Still available lol most likely also updating the bumpers as well.
  20. Oct 11, 2023 at 7:31 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Any idea what’s going on with the other tundra up front?
  21. Oct 11, 2023 at 7:56 AM
    reywcms
    Rey
    North Plains,Oregon
    There's a few rigs in there getting LSK kits and LSK rear link kits
    Mater[QUOTED] likes this.
  22. Oct 11, 2023 at 11:32 AM
    coTony
    Tony
    Montrose, CO
    I can swing by and dispose of them for you :spy:
  23. Oct 11, 2023 at 11:35 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    With a core charge of 7k
    coTony[QUOTED] and reywcms[OP] like this.
  24. Nov 7, 2023 at 7:43 PM
    reywcms
    Rey
    North Plains,Oregon
    Build update 11/7/23 Bumpers, front glass and all mounts off the rig. Bed should be off here shortly. The rear bumper is available if anyone interested confirming a price and will post soon. Hope to have more progress pics here soon of his build.
    mayan, TRDFerguson, n0rth and 5 others like this.
  25. Nov 7, 2023 at 7:51 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    His build is going as slow as mine :rofl:
  26. Nov 7, 2023 at 7:56 PM
    reywcms
    Rey
    North Plains,Oregon
    Yea it is lol you might be done before lol
  27. Nov 7, 2023 at 11:04 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Looking forward to seeing more progress! Wish my old man’s tundra was that badass lol
  28. Nov 8, 2023 at 4:33 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I thought that shop looked familiar. They always seem to have some cool projects going on in there.
  29. Dec 18, 2023 at 11:16 AM
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    How about a little reverse engineering write up on those liners with the glass...haha??? I know Tav does them custom, but I have never seen him actually talk about the design, material, and how they attach them.
  30. Dec 18, 2023 at 12:26 PM
    reywcms
    Rey
    North Plains,Oregon
    It’s just abs plastic heated to shape then screwed in. Same type of abs used for valence etc.
    mista_g[QUOTED] likes this.
