Window Weather Strips
Discussion in '2nd Gen Tundras (2007-2013)' started by Albinator, Oct 1, 2023.
  1. Oct 1, 2023 at 7:01 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Hey Everyone,
    I am in need of weather strips for my crewmax windows. One is torn and that is the culprit of why my truck has the smell of moisture on the inside after rainstorms.
    Do you recommend going oem on these things or offbrand like from Amazon or eBay? I’m finding the 4 set around 32-50ish dollars.
  2. Oct 1, 2023 at 7:09 PM
    Albinator
    Utah
    for every part or certain parts? And is “if you can” regards to cost?
  3. Oct 1, 2023 at 7:13 PM
    EmergencyMaximum
    Definitely OEM, but if feeling adventurous, pick one up off ebay and let us know your results!!
    Not being cheeky or anything, just for science! I got chinabay ones for my roof molding part and they didn't work. They were almost identical, except for one little detail that made them pop out. Feels like they never tried that part on actual tundra.
    Albinator[OP] likes this.
  4. Oct 2, 2023 at 10:24 AM
    Triggerman07
    Triggerman07 New Member
    2007 4x4 Crew Max Limited
    Boomer Topper. New Tires. Glued together drivers seat.
    If you are referring to window belt molding, be advised these Do Not prevent water for going down into the door. Nothing can prevent that; doors are designed to manage water coming in and draining out the bottom drain holes (thus the vapor barrier behind the plastic door panel etc.) So if you have a smell you may need to look elsewhere.
    EmergencyMaximum likes this.
  5. Oct 2, 2023 at 11:18 AM
    Albinator
    Utah
    So this picture I took (attached) isn’t a necessary thing to replace for keeping water out of electrical component places? It seems that a good amount of water pools in these seams so I don’t see how it doesn’t help with keeping water mostly out.
  6. Oct 2, 2023 at 11:27 AM
    Triggerman07
    Window molding is really there to help prevent debris from getting inside the door during the natural travel of the water through the door (it "travels" down behind the outer door skin) as it exits out of the drain holes. Bend down and gently pull up the lower door/rocker rubber seal, you will see the drain holes. Its kinda important these drain holes don't get clogged up.
  7. Oct 2, 2023 at 11:32 AM
    Triggerman07
  8. Oct 2, 2023 at 11:45 AM
    Albinator
    Utah
    Great info, thanks! I did not know about the drain holes at the bottom of the door.
    Im assuming it’s still wise to replace these though since it keeps things out and seems to help with some moisture?
