  1. Oct 2, 2023 at 9:15 AM
    danb
    danb New Member
    Minnesota
    2018 Tundra DC Looooooong bed
    I've been spraying lithium grease on everything to try and isolate the sound. Could be that or t case fluid
  2. Oct 2, 2023 at 9:15 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Send a white zip tie down in there like a dip stick.
    oscardog86 and FrenchToasty like this.
  3. Oct 2, 2023 at 9:33 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Should weep a little once you crack the fill plug (if full), but the finger test is always more fun.
    oscardog86 and FirstGenVol like this.
  4. Oct 2, 2023 at 9:35 AM
    I'm gonna redirect convo back to your thread, since (with videos and all) this would probably help someone else down the road if kept in one place, not buried in the WHYDTY1GT thread: https://www.tundras.com/threads/transfer-case-squealing-anyone-else-have-this-problem.131100/
    Voss and Mr.bee like this.
  5. Oct 2, 2023 at 9:38 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I checked on them.. there’s 0 in the country.
  6. Oct 2, 2023 at 9:38 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If it has fluid, remove the driveshaft from the t-case and spin the t-case flange, that'll help you isolate the noise.
    oscardog86, danb, Voss and 2 others like this.
  7. Oct 2, 2023 at 11:02 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Oh, good to know thanks
  8. Oct 2, 2023 at 11:04 AM
    Voss
    2003 AC TRD 4x4
    I had a similar sound when my driveshaft center bearing needed replacing…
    DJenerated likes this.
  9. Oct 2, 2023 at 12:24 PM
    danb
    danb New Member
    Minnesota
    driveshaft and center bearing is all new within past 1000 miles so hopefully thats not it
    Voss[QUOTED] likes this.
  10. Oct 2, 2023 at 1:05 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    I haven't done anything to my truck today besides fill it up and spend $128 doing it. But to make me feel better, I just discovered the crotch vent directly under the steering wheel. This must be why these trucks are so highly regarded. I've never seen a vehicle with this, and I love that it works on the regular fan setting, not just the feet. Made my day!
  11. Oct 2, 2023 at 1:09 PM
    That's the Turbo Goochcooler 9000. Only on a Best Gen. Well, that and my dad's old 77 chevy had one too.
    https://www.youtube.com/watch?v=UOYpCZzpbiI
  12. Oct 2, 2023 at 1:15 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Aka the cock cooler aka the koochie cooler
    dirtnsmores and KNABORES[QUOTED] like this.
  13. Oct 2, 2023 at 1:26 PM
  14. Oct 2, 2023 at 3:19 PM
    Voss
    2003 AC TRD 4x4
    Is the new center bearing OEM?
  15. Oct 2, 2023 at 3:46 PM
    danb
    danb New Member
    Minnesota
    negative, whatever was on the replacement. debating returning the driveshaft to o reallys because its been a source of noise and vibration since install and rebuilding my rusted out one
  16. Oct 2, 2023 at 4:02 PM
    Voss
    2003 AC TRD 4x4
    Had this issue when they 1st used an aftermarket center bearing when I replaced mine. Lasted about a month. Changed out for OEM.
    Prob wanna follow what Brent said about disconnecting your drive shaft from pumpkin to know where the sound is coming from.
    txagg and danb[QUOTED] like this.
  17. Oct 2, 2023 at 4:07 PM
    danb
    danb New Member
    Minnesota
    damn just a month, that sucks ass. and thats the plan tomorrow, disconnect and spin more shit
    Voss[QUOTED] and shifty` like this.
  18. Oct 2, 2023 at 4:19 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    We had one on the 1972 Chrysler Wagon. Just offset to the left a bit.
  19. Oct 2, 2023 at 5:38 PM
    bfunke
    bfunke Tundra Curmudgeon
    Speicher makes the OEM carrier bearing.
    Voss and DJenerated like this.
  20. Oct 2, 2023 at 5:41 PM
    DJenerated
    Dija
    The Lone Star State
    I thought it was Spicer
  21. Oct 2, 2023 at 5:42 PM
    Spicier than what
  22. Oct 2, 2023 at 5:47 PM
    DJenerated
    Dija
    The Lone Star State
  23. Oct 3, 2023 at 7:21 AM
    metalpete
    ID
    Bummer news, dudes. The struts from Toytec aren't coming in until mid November. Thought it was just going to be a couple weeks out, but I knew better, so I'm not mad...just disappointed.
    Worst part is, I need new tires soon. Was hoping to have the extra lift before tires/wheel, but maybe I can stuff the tires in there and wait it out.
  24. Oct 3, 2023 at 8:01 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I fit 275/60r20 on stock worn out suspension but i was extra gentle through tight turns like parking lots. They're kinda worn out, so maybe 32's instead of 33's. Those wheels are +18 offset, and rubbed the uca's a hair, but not when jacked up off the ground...not enough to rub the paint off.
    metalpete[QUOTED] likes this.
  25. Oct 3, 2023 at 9:11 AM
    metalpete
    ID
    Thanks @Mr.bee. My current set up basically leveled the truck (1.75" lift) and I do have aftermarket UCA's, so maybe stuffing the 285/70/17's I want won't be too bad after all.
    I'll just take it nice and easy on those turns, too.
  26. Oct 3, 2023 at 9:32 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Is it pos or neg offset that pokes the wheels out further? The sequoia that those wheels/tires were on was lifted & had spacers.
  27. Oct 3, 2023 at 9:39 AM
    metalpete
    ID
    Negative offset makes the wheels stick out further. I think I have 265/70's on right now... things that make you go "hmm".
  28. Oct 3, 2023 at 10:12 AM
    With offset being variable based on wheel width, maybe better to say "lower backspace = more poke" or something. At 8" width w/0 offset you'd have the same poke I had on 17x9" w/-12 offset.
    More-universal may be to say ~4.5" backspace is roughly flush with fender flares at 8.5-9" width, 4.75" BS is tucked just inside fender flares at 8.5-9" width, stock is 5.0" at 7.5" width.
    I'm just talking aloud, not criticizing.
  29. Oct 3, 2023 at 11:37 AM
    metalpete
    ID
    No no! That's perfect info, @shifty`
    I know almost nothing when it comes to wheels and what they do...besides tires go on them so the truck can roll lol.
    shifty` likes this.
  30. Oct 3, 2023 at 12:55 PM
    I always hafta go back and re-learn this crap every time I buy new wheels. It's aggravating as hell. The info makes sense once I get back into it, then 2, 3, 4 years later when I need another set of wheels for a project, I realize I lost it all again.
    And y'all probably saw what happened to me this last time. I ended up buying two sets of wheels. And that is gonna cost me too... Already getting yelled at for eating up space in the house with those and my OEM wheels.
