Ahmed hates metal oil filter cannisters
Discussion in '2.5 Gen Tundras (2014-2021)' started by DaveInTexas, Oct 1, 2023.
  1. Oct 1, 2023 at 3:59 PM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    and spin-on filter modifications.
    All agree?
    EDIT - a plea to ignore the thread if you find it annoying. Better for you, better for participants. Some of us still find things to learn about it.
    Also, the two things I have not seen discussed so far is a) he makes a lot of mention of the bypass spring tension and that the Dorman etc metal cannisters may not have the correct pressure. It is a defined spec that is being ignored. The spring may have tension that is too light (opens too early) or tight (does not open when needed) and b) if you pull the center tube off, in order to swap it out etc, it somehow weakens the parts and it should all be tossed.
    Thank you-
    https://youtu.be/G_vl2AYe7Yg?si=D3KwURGnz1z3NzMR
    Mike59 likes this.
  2. Oct 1, 2023 at 8:11 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Been posted in many threads. Its common knowledge that the only reason people started buying the metal one and cannibalizing it to work was because they broke their plastic one but the only reason the plastic one breaks is because it torqued too much to begin with. When used properly the plastic one doesn't have any issues. Im at almost 50,000 miles with 8+ oil changes, no issues because no one has touched it but me.
    Mike59, TWJLee and FrenchToasty like this.
  3. Oct 1, 2023 at 8:18 PM
    AZBoatHauler
    So.Arizona
  4. Oct 1, 2023 at 8:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    What about the people that aren't able to change their own oil and have to get it done at Jiffy Lube or the Dealership ? This talking point that its somehow "cannibalizing" the original system has been debunked here multiple times, its the same exact housing except its metal with the same pressure relief valve when swapped over. Not sure why you continue to try to scare people when there's no evidence of any problems with the swap.
  5. Oct 1, 2023 at 8:49 PM
    Joe333x
    Joe333x Member
    Boston
    I have yet to read a post about someone having a shop break their oil filter housing, just people on here breaking thier own. If a shop breaks it, chances are they are going to also replace it. Also have seen posts on here with people installing the housing with the wrong tube, no tube, the tube not being connected ect. If you did yours and your happy with it, thats totally fine. I just try to spread factual first hand information about my own filter housing and the words of the Toyota master mechanic telling you not to do it either.
    MrJimmyPenguin likes this.
  6. Oct 1, 2023 at 9:03 PM
    TILLY
    Massachusetts
    I can't speak for those who can't follow even basic instructions on something this simple, we try to direct them in the right direction here. As far as trusting one Tech for all the decisions you make, that's on you.
  7. Oct 1, 2023 at 9:06 PM
    Joe333x
    Joe333x Member
    Boston
    I think hes a wealth of knowledge. Personally I decided to keep my plastic housing before he made the video, Ive had my truck since 2019, he just put that video out recently. I actually had the metal can in my cart to order for awhile but after a couple oil changes seen no reason to. If it works why fix it.
  8. Oct 1, 2023 at 9:17 PM
    TILLY
    Massachusetts
    I've said multiple times, do what makes you happy, its all good.
  9. Oct 1, 2023 at 9:51 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    potayto, potahto
    The aluminum one was originally a Lexus-spec'd part for the same engine. I swapped the one on my 2008 within a few thousand miles of buying it and ran it with the metal one for just shy of 300,000 miles without issue. I did the same on my 2021 once I was done with the "Toyota Care" oil changes and started doing my own, and now have several changes behind me with the same lack of issues.
    You do you, and I'll do me.
    :burp:
    schleinj, Mike59 and gosolo like this.
  10. Oct 1, 2023 at 9:58 PM
    Joe333x
    Joe333x Member
    Boston
    Curious which model lexus?
  11. Oct 1, 2023 at 10:05 PM
    AZBoatHauler
    So.Arizona
    I’m sure it fits a ton of models but the ES 350 uses the same part. Any Lexus with a 3.5.
    Looks like ES, RX, NX, RC and some LS models.
    gosolo likes this.
  12. Oct 1, 2023 at 10:06 PM
    Retroboy1989
    Northern Utah
    This thread again?
    If you don't care/don't want to spend the money - leave the plastic one.
    If you want an aluminum one, buy an aluminum one. (Be sure to swap the metal tube for length and holds the proper bypass spring)
    This really is not worth debating further.
    bulldog93 and Gene_in_FL like this.
  13. Oct 1, 2023 at 10:07 PM
    Joe333x
    Joe333x Member
    Boston
    From what I can find part number (15620-31060) fits Avalon, Camry, Highlander, RAV4, Sienna, Venza. Obviously none of those had a 3URFE V8. So if there was a lexus with the 3UR and a metal housing it had to be a different part number and would likely have the correct size tube, definitely would be great if you had that info. @RainMan_PNW
    https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-engine-oil-filter-housing-1562031060
  14. Oct 1, 2023 at 10:11 PM
    AZBoatHauler
    So.Arizona
    https://parts.lexus.com/p/Lexus__/CAP-ASSEMBLY---OIL-FILTER/62914429/1562031060.html
    Mike59, gosolo and bulldog93 like this.
  15. Oct 1, 2023 at 10:11 PM
    AZBoatHauler
    So.Arizona
    Look on a Lexus parts site. That helps.
  16. Oct 1, 2023 at 10:13 PM
    Joe333x
    Joe333x Member
    Boston
    Still not seeing where it was used on the same engine. Found part number 156500S010 for the LX570 which had the same engine but a search shows that also had a plastic cap. If there was another lexus with a 3UR I am unaware but intrigued because if there was actually a lexus 5.7 with a metal cap then it should be a direct swap with out any tube swapping. Im not actually targeting you, it was @RainMan_PNW that said it came from a lexus with the same engine.
  17. Oct 1, 2023 at 10:45 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
  18. Oct 1, 2023 at 10:49 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Quite agree.
    When Car Care Legume said 0W-20 is killing your engine, there was mass compliance and endless referencing. To question was to be a heretic.
    Car Care Legume says use the plastic canister.
    Do it now. Do not question. Do not debate. Do not interpret.
    Comply.
  19. Oct 1, 2023 at 10:51 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I agree, lets not discuss this anymore...lets talk about how shitty the gas mileage is. Just pretending to give a shit. People its a 3 ton brick, what the hell do you expect, my window sticker clearly states 14 mpg, what the hell is so hard to understand?
  20. Oct 1, 2023 at 11:10 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    *cough cough…. Mine is a 3.6 ton brick, thank you very much!
    Part of the extra weight is no doubt from the aluminum mini van filter housing.
    Some folks just need to be right, and can’t pass up a good opportunity to just shut up. Part of forum life…
  21. Oct 1, 2023 at 11:12 PM
    Joe333x
    Joe333x Member
    Boston
    bulldog93 likes this.
  22. Oct 2, 2023 at 2:58 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I don't need to be right, I just am. I don't do it on purpose, I was just born that way. Some people are born with athleticism, some are good at math, etc. I was born with being right all the time. I wish people would just accept me for who I am.
  23. Oct 2, 2023 at 5:04 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Ok well now this has me worried; i literally just swapped mine out for the aluminum housing this weekend. Anyone know the part number of the oem plastic one?
  24. Oct 2, 2023 at 6:09 AM
    Bammer
    Monroe, CT
    Stop playing into the rhetoric, lot more things to worry about. Let it be.......................:rasta:
    WFD473 likes this.
  25. Oct 2, 2023 at 7:28 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Someone here will trade you for your aluminum one. And neither one of you will have any problems! :bananadance:
    Mike59 and WFD473 like this.
  26. Oct 2, 2023 at 7:57 AM
    DaveInTexas
    Dave
    West Texas
    Thank you
    Also, I pulled my 4R cannister off after the dealer had changed the oil 5K mi before and as usual they had torqued it to 120ft-lbs. Even accounting for stiction, there is no way they torqued it properly. Removing it cracked the plastic housing and I was in a bind so I ran to the parts store and installed a non-OEM metal one. Now I see Ahmed's video, was worried for a while but I'm over it.
  27. Oct 2, 2023 at 8:57 AM
    shawn474
    MoCo, Maryland
    So you're saying that you swapped yours out with the Dorman aftermarket and haven't had any issues? If so that makes me feel better......
  28. Oct 2, 2023 at 9:07 AM
    DaveInTexas
    Dave
    West Texas
    This is the case.
    However, I have no way of knowing if the spring is allowing bypass when it is needed.
    I suppose if the filter is exceedingly clean next change, I might think it was always open.
    Not sure what I will do. I might still swap it for an OEM. Ahmed has some very good info usually.
    shawn474[QUOTED] likes this.
  29. Oct 2, 2023 at 9:10 AM
    shawn474
    MoCo, Maryland
    I will do the same - I have my original plastic one so may swap it if the filter is exceptionally clean.....
  30. Oct 2, 2023 at 10:28 AM
    shawn474
    MoCo, Maryland
    So all this got me thinking - I KNOW I put 8.5 quarts of 0w-20 in……checked the dipstick this morning and it looks like is is reading a little high. Truck has been sitting overnight on level surface. Should I drain a half a quart?
