2014 SR5, Need bright, inexpensive headlights
Discussion in 'Lighting' started by Cronion, Oct 1, 2023.
  1. Oct 1, 2023 at 8:50 AM
    Cronion
    Cronion [OP] New Member
    I don’t want a big project or expensive conversion but need recommendations for a bright bulb(high/low beams). My profile pic shows the style I have. I am unhappy with my SEALIGHT H4 9003 LED Bulbs from Amazon as the high beams are barely visible. They are installed & focused correctly but are a complete joke.
  2. Oct 1, 2023 at 9:04 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It is known on the forum that LED bulbs don't work very well in Tundra Halogen headlight assemblies.
    I used these for years before I did the 2018+ OEM LED conversion.
    I felt they worked pretty good, but nowhere as good as the OEM LED headlights.
    Good luck.
    Amazon.com: SYLVANIA - 9003 SilverStar - High Performance Halogen Headlight Bulb, High Beam, Low Beam and Fog Replacement Bulb, Brighter Downroad with Whiter Light (Contains 2 Bulbs) : Automotive
    BlueRibbon4x4 and Cronion[OP] like this.
  3. Oct 1, 2023 at 6:33 PM
    Cronion
    Wow, that explains things, and of course, makes good sense. Thank you for your help!
    1lowlife likes this.
  4. Oct 1, 2023 at 6:43 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Sure..
    Save your pennies, the 2018+ OEM LED conversion is SO worth the money.
    Not only better lighting, but the headlights look better..
    I did it a few years ago using an @iHacker harness.
    One of the best mods I've ever done on my 2014.
    2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0] | Toyota Tundra Forum (tundras.com)
    Old OEM stock halogens
    AD0747A0-2452-48A4-AD35-0360A15C02D0_zps_856d7f7698c44d429becac8957196204f8177f26.jpg
    Replaced those with OEM halogen TRD Pro (blacked out)
    94B1C49A-A66D-4F31-99DA-6BD45F492426_zps_1880508731d819dfee9b9f1441c35f1a10921424.jpg
    OEM LED TRD Pro (blacked out)
    equin likes this.
