Help!!! Need rear shock entendres
Discussion in 'Suspension' started by Sonicbluerider, Sep 26, 2023.
  1. Sep 26, 2023 at 2:47 PM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    Ok fox 2.5 on rear adding new leaf springs 1400 lb alcans. I carry a four wheel camper, the shop says now my shocks won't connect with my camper off. So I need to buy extensions for my shocks!!! who ,where can I get some shock extensions?? 2019 limited cm
  2. Sep 26, 2023 at 4:44 PM
    blenton
    blenton New Member
    How much lift did you order with the Alcans? Pics?
  3. Sep 26, 2023 at 4:47 PM
    And what is the lift range for the shocks?
  4. Sep 26, 2023 at 4:50 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Supposed to be just 1" but with camper off it's really high. Hoping it will lower to proper hight when camper installed. Fox 2.5 so guessing 2.5
  5. Sep 26, 2023 at 4:51 PM
    2.5 is the shock body size (2.5”), not the lift.
  6. Sep 28, 2023 at 9:04 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    well put camper on all fitted...yaaaaa
    KNABORES likes this.
  7. Sep 28, 2023 at 9:19 AM
    :worthless:
  8. Sep 30, 2023 at 11:27 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    If you go with longer shocks to work when unloaded, they’ll likely be too long when the camper is on.
    Seems a little strange, but I suppose you could install limiting straps to prevent over-extension…
    Before I did that though, I’d confirm that you have the correct shock length to begin with. Alcan should be able to assist with fitment, I’d think.
