General Supercharger Thread
  1. Sep 29, 2023 at 9:02 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I think one issue you'll see people don't keep cars that long. There's no reason for this platform not to exceed the 300k mark with a supercharger. Comes down to maintenance and use case. These motors are very stout forged crank, rods etc. The tuning is also a huge factor. How do you use your rig? It sounds like your mind is made up on not having one. Do you feel this way about other mods as well? With that mind set leave the thing stock.
    Saltyhero13, Silver17, Mdl and 2 others like this.
  2. Sep 29, 2023 at 9:12 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Definitely not opposed to modding and I haven't made up my mind 100%.
    Like most of us, I'm driving this 90% on the road. I live up in the mountains just outside city so I'm driving in and out of the mountains daily. Steep hills and windy roads and then once down, I'm on the freeway and around town. I'm a mix of moderate and aggressive driving. It will go off-road a few times a month, but mainly fire and logging roads only because I don't want to beat it up on narrow trails and rocks.
    I'd say I'm average use case, but I will hammer the shit out of it semi regularly on the road.
    Also, regardless of how I'm driving, I'm a 5K oil change, religiously.
  3. Sep 29, 2023 at 9:15 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    You’re just never gonna see 20-30+ examples of supercharged trucks being discussed with 300k+ miles IMO. That’s not necessarily because they can’t make it that far, but because there isn’t that many SCd trucks out there. The ones that are out there for the most part aren’t being daily driven and commuted in racking up miles. Who wants to drive their truck that requires premium and would generally be a vehicle you would keep for nice/fun often enough to rack up that kind of mileage. I drive mine 8k a year. That said I’ve probably seen at least 10 examples of SC trucks with over 225k across the various platforms.
  4. Sep 29, 2023 at 9:17 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    That's the problem with the Internet, you only hear from the people having problems. As the OG Maggy was sold by Toyota as a TRD kit, there are thousands of them out there, sold to the non-enthusiast crowd, with tons of miles on them. The only way to track those is when we run across a seemingly stock truck for sale online that's been SC since new with lots of miles.
    That's not specifically the 2650, but Magnuson was OEM for the TRD kit too.
  5. Sep 29, 2023 at 10:31 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You will have to post a sound bite. I'd love to hear it especially dumped after those big berthas!
  6. Sep 29, 2023 at 12:23 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    VFTuner needing to have tundra ECUs physically shipped ended in 2020/21. Definitely no later than September 2021 when I gifted Mat with a treasure trove of TSB CUW files with which to build tune support with any need to be pulling the ECMs.
    Wynnded[QUOTED] likes this.
  7. Sep 29, 2023 at 12:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @eZKimChi
  8. Sep 29, 2023 at 1:42 PM
    mZiggy
    mZiggy Honey badger
    Marc
    If there's a need to pull ecu still, it's certainly news to me lol
    HulkSmurf14 and Wynnded like this.
  9. Sep 30, 2023 at 7:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    it got delivered.
    but....20' 1794 pkg does not have that blank spare button thing.
    so I will jury-rig it. as all grown-ass men do.
    drill a small hole & it should work just fine. the mount is very straight forward.
    stock small girth TRD intake goes in today
    since it's Africa hot today, I reckon I'll count this as exercise - as I will sweat off 5lbs.
    Saltyhero13 and nasher75 like this.
  10. Sep 30, 2023 at 9:58 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    @Mdl little box for big gains going out.
    I was also recently informed of someone who was pushing big power with one of the Sniv Speed Shop pulleys to the point his (stock) engine left the chat. Which sucks, but also kind of cool to see an example of how far the engine can be pushed and the SSS pulley being able to help deliver enough power to reach that point.
  11. Sep 30, 2023 at 10:12 AM
    snivilous
    SW UT
    And I guess I should enlighten that post a bit. Maybe dude will post on here, but he was in the mid teens for boost and from the sounds of it at WOT for 30 seconds or longer. Not sure of what other mods he had, but it was a 2.0" pulley at sea level. Very super rough my guess is that's ~575whp and ~700+ at the crank? Not sure of the horsepower efficiency drop off as you push that much boost through a 1.9L Magnuson. High 10/low 11 AFR.
    It's actually kind of impressive to me the engine was able to hold that together for that long on a stock short block. That's a long pull in general let alone at that boost. I wonder for your guy that's just merging on the interstate and stop light racing if that much power could be run reliably for awhile. My truck and many of us routinely tap at the 10-11psi range with that kind of driving style of just short sprints, so maybe 13, 14, 15psi the engine can handle too if it's not rung out for a long time?
    Food for thought and one data point to keep in mind.
  12. Sep 30, 2023 at 10:22 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    sending vibes of condolences in that general direction.
    we shall name him Icarus.
  13. Sep 30, 2023 at 10:27 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    WOT @ 30 seconds or longer.. surprised the tires that probably aren't rated to go over 100mph didn't go first
  14. Sep 30, 2023 at 11:51 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Welcome.
    This has been brought up before; I think 200K is reasonable if you don't get greedy on WHP without building the bottom end up.
    https://www.tundras.com/threads/supercharger-long-term-reliability.11689/
    nasher75[QUOTED] likes this.
  15. Sep 30, 2023 at 11:52 AM
    Saltyhero13
    nags[QUOTED] likes this.
  16. Sep 30, 2023 at 11:54 AM
    Saltyhero13
    Lots of gold nuggets in that one. TB size, screw vs roots, blower sizing.
    reywcms likes this.
  17. Sep 30, 2023 at 12:03 PM
    Saltyhero13
    nasher75 and Mdl like this.
  18. Sep 30, 2023 at 12:22 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Last night I drove from L.A. to Phoenix, in the middle of the desert/nowhere I was escaping an asshat BMW for over 100 miles that kept riding up my ass, I was cruising at 85-90 and in seconds was going 120 & he was 10+ car lengths back, over & over, highest boost I saw was 8.7, it was 80 degrees.
    Gotta love boost!
  19. Sep 30, 2023 at 12:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous thanks!
    Been down that road... my last engine was pushing 11.5 to 13psi, depending on air temp and density. It was theoretically making 600whp. I'm between 9 and 10psi now. Will get intake and injectors setup before putting an extra 2psi at it. May order a 2.3 in case. ;)
    I forgot where I heard it but the tvs 1900 turns into a heat pump and has major parasytic loss after 13psi.
    reywcms and snivilous[OP] like this.
  20. Sep 30, 2023 at 1:43 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
  21. Sep 30, 2023 at 2:40 PM
    snivilous
    SW UT
    Yea I wouldn't be surprised. I know the LSA superchargers which are also 1.9L can push around 15psi and they're pretty topped out, spin it faster and nothing really happens unless you seriously modify them. I've assumed the Magnuson is pretty similar. That's part of the reason the smallest pulley I decided for was 2.0" since going smaller (which is possible) sounded like it'd quickly have serious diminishing returns.
  22. Sep 30, 2023 at 2:46 PM
    Silver17
    Eastern PA
    If it was the guy I think it is as seen on other threads, he was pushing 13+psi with longtube headers and full exhaust which also drop the boost pressure a bit. Considering that I guess I’m not surprised it blew! Agreed with @V10Ace about WOT for 30 seconds, must have been going crazy fast. My trip down the 1/4 mile strip I was at 100mph in 13ish seconds from a standstill, so how fast was dude going in a pickup!? Had to have hit 140+ lol.
  23. Sep 30, 2023 at 2:46 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I will be selling my 2.3 once my short block comes in.
  24. Sep 30, 2023 at 3:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When mine met its demise I was on a long wot as I was pulling away from a hellcat. I believe my fuel system and pump was tapped out(plus the shitty BD tune). The intake valley by cylinder 8 had a hole melted clean through. Plus a few rods wrapped up in the crank. If I sell and move I'll be ordering up a built block.
    snivilous[OP] and Saltyhero13 like this.
  25. Sep 30, 2023 at 3:45 PM
    Saltyhero13
    A post mortem would have been nice but doesn't matter for what you're asking. A supercharger certainly wont extend the life of an engine. If you want a forever truck you are probably better off not boosting your truck.
    nasher75[QUOTED] and Mdl like this.
  26. Sep 30, 2023 at 4:02 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I totally think this is an extreme case. Long long pulls on this with the rings being a concern is no bueno. I agree that for the random short stints I don’t foresee the same demise. There’s just less chance for the heat and strain. Built motor problem solved lol
  27. Sep 30, 2023 at 4:30 PM
    Silver17
    Eastern PA
    Also, with the same boost with cooler IATs (bigger blower) maybe that could have delayed the kaboom?
  28. Sep 30, 2023 at 4:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I agree 100% on that. We ran into this very same issue in the cobra world. I grenaded my motor from a long freeway pull over spinning the Eaton or Heaton we called it back when. Bigger blower cars lasted much longer on the stock long block. Those had very tight piston clearance issues.
  29. Sep 30, 2023 at 5:23 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Also wondering how much help a water meth kit would’ve done? Can’t hurt
    Mdl and VWTim like this.
  30. Sep 30, 2023 at 6:07 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm kinda following firemandan's setup. Not sure about the methanol setup...would be nice to keep things in check.
    nags likes this.
