Help with trd pro skid plate install
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cfincke, Mar 11, 2017.
  1. Apr 7, 2018 at 6:36 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    RCI Skids from Toytec.
    15whtrd and nk1794 like this.
  2. Apr 7, 2018 at 6:38 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    What are the pros and cons when comparing to the TRD?
  3. Apr 7, 2018 at 6:39 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    That is where the drain plug is, give or take. Just a little visual
    nk1794 likes this.
  4. Apr 7, 2018 at 6:41 AM
    nk1794
    San Jose, CA
    It definitely looks better than the stock plate.
  5. Apr 7, 2018 at 6:53 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I thought for the money the RCI skid was a better setup. It has more options and seems well engineered. The fellas at Toytec highly recommend them.
    I am changing mine out just for oil change ease and that is what I’m going with.
    15whtrd and nk1794[QUOTED] like this.
  6. Apr 7, 2018 at 7:42 AM
    Johnathand
    Johnathand New Member
    Johnathan
    16 Platinum
    Bought a TRD SKID also without the hardware. I was cheap... and had a little time. Basically 30-45 min at Home Depot. I pieced together everything, with the exception of the large square middle spacer. Luckily the guy included that. But 45 minutes and $8.00 later I had everything I needed.
    My skid is bolted on tight, no missing bolts. Couldn’t tell it wasn’t the $90.00 oem bolt kit.
    equin, nk1794 and BTBAKER like this.
  7. Apr 7, 2018 at 7:43 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    90 bucks. Damn..:facepalm:
  8. Apr 9, 2018 at 10:10 AM
    nk1794
    San Jose, CA
    Rivets? Really?
  9. Apr 9, 2018 at 12:04 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Yup, there is a small flexible shield on the front of the skid plate that is attached with rivets. Should be already attached, but the HW kit comes with ALL hardware.
    nk1794[QUOTED] likes this.
  10. Apr 9, 2018 at 12:14 PM
    nk1794
    San Jose, CA
    Thanks
  11. Jan 15, 2022 at 5:54 AM
    Bigbird57
    Bigbird57 New Member
    What length are the spacers on the long bolts?
  12. Mar 19, 2022 at 9:29 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    @AZTundra this is not only it, but whatever we’re missing we can find based off the descriptions added above, how great
    AZTundra likes this.
  13. Mar 19, 2022 at 9:59 AM
    AZTundra
    Paul
    Phoenix, AZ
    Perfect. Thank you.
    adamreinhardt[QUOTED] likes this.
  14. Mar 30, 2022 at 8:11 PM
    MALIBU1794DC
    MALIBU1794DC New Member
    2019 Double cab 1794
    This thread is a good resource for getting the hardware
  15. Sep 27, 2023 at 4:27 AM
    Jnickoles
    Jnickoles New Member
    2021 Tundra sr5
    Old thread, I know, but does anyone know if that large square aluminum block that goes in the middle of the skid plate is included in the hardware kit?
  16. Sep 27, 2023 at 5:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes
    If you are referring to the piece shown in this post
  17. Sep 27, 2023 at 6:13 AM
    Jnickoles
    2021 Tundra sr5
    Yea this part is included in the hardware kit?
  18. Sep 29, 2023 at 9:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Supposed to be - that part is the “Jack spacer extrusion” I believe.
