2006 Side Mirror Cap Remove/ Replace
Discussion in '1st Gen Tundras (2000-2006)' started by HBTundra, Dec 27, 2022.
  1. Dec 27, 2022 at 9:01 AM
    HBTundra
    HBTundra [OP] New Member
    2006 DC 2wd
    Got a buddy that will wrap my chrome side mirror caps.
    Said it's better to remove them to wrap around the complete edge.
    How tricky is it to remove just the chrome caps on these trucks?
    TIA.
  2. Dec 27, 2022 at 9:29 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Oh...I want to know this! Following...
  3. Dec 27, 2022 at 9:50 AM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    It’s pretty easy, just remove the mirror glass (it pulls off) then you’ll see 5 or 6 tabs that you can release with a flathead screwdriver. You’ll probably break a tab or two but it’s no big deal. When removing mine, I broke one tab on each cap pulling them off, but they still clip in securely. You can check out the 1AAuto video on mirror removal for our trucks to see the process visually.
    N84434 and HBTundra[OP] like this.
  4. Dec 27, 2022 at 10:00 AM
    HBTundra
    2006 DC 2wd
    Thank You Sir.
    Glad I posted instead of going out there & trying to pry / pop them off.
    Much appreciated.
    Will report back if I go for it.
    Acatlin96[QUOTED] likes this.
  5. Dec 27, 2022 at 10:59 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Spot on. Last summer I bought a roll of Chrome wrap and pulled my caps and wrapped them. It worked out very well and was super easy to accomplish. You're gonna love the way it looks...
  6. Dec 27, 2022 at 11:42 AM
    HBTundra
    2006 DC 2wd
    Talked to my buddy . . . he remembered doing his Gen 1 Tundra . . . said it was a little sketchy with the potential to break the mirror, and the tabs on the back.
    He's just going to do them in place and use a little primer-prep around the edges to minimize pull-back.
    It'll be matte-black over the chrome and said I may see a tiny little bit of the chrome if you get up close and look for it . . . no biggie for me. I don't want to be on a parts hunt for broken mirror pieces over something cosmetic. Plus I can yank it off in a year or so if I don't like it.
  7. Dec 27, 2022 at 2:24 PM
    It can be a PITA to pop the mirror off. It's best to tape the glass before removing. I had to swap out one of mine after someone/something smashed my passenger side. Here are the OEM paper instructions from Toyota I posted in the 'What'd You Do' thread many moons ago: https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-678#post-1820473
    I think that reply also includes a link to Sue's video for removal, and other tips. Check it out.
    Sometimes if you heat tabs on parts, they're less prone to snapping off at removal time....
  8. Dec 27, 2022 at 2:38 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  9. Dec 27, 2022 at 2:39 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Fair warning...... you may not be happy with the results if you don't wrap the edges over the cap. That stuff will shrink and with out the edge to wrap around, it'll be a pain in the neck to keep the wrap tight and secure to the mirror cap.
    1lowlife and HBTundra[OP] like this.
  10. Sep 28, 2023 at 7:41 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I removed my drivers side pretty easily with patience and this plastic tool. No broken tabs
    HBTundra[OP], shifty` and w666 like this.
  11. Sep 28, 2023 at 8:02 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    DONE. no broken tabs :)
    w666 likes this.
  12. Sep 28, 2023 at 8:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    someone may need this image for future reference
    HBTundra[OP] and w666 like this.
  13. Sep 29, 2023 at 8:31 AM
    Did you manage that without removing the mirror glass?
  14. Sep 29, 2023 at 8:54 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes. Lightly separated enough with a small flat head screwdriver enough to allow penetration of the plastic trim tool. Then slowly moved it around in a circle to release the clips.
    HBTundra[OP] and shifty`[QUOTED] like this.
  15. Sep 29, 2023 at 9:02 AM
    Nice! You're the 1st person I've seen show this is something possible to do.
    I guess the next question is ... are you replacing, color-matching, or ??
  16. Sep 29, 2023 at 9:17 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Rattle can paint silver.
    EDIT: Ignorance is bliss. I did it before reading the forum :rofl:
    shifty`[QUOTED] likes this.
  17. Sep 29, 2023 at 9:36 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Here is the post from my thread doing it. A couple pictures down it shows the cap side and mirror side and can see where the little tabs are. I used a metal pick with a 90* tip to get around and bend back the tabs. I bought mirrors off ebay with matching caps and basically broke the chrome caps off my mirrors and broke the other mirrors so I could use the color-matched caps. So maybe don't do that, but maybe this will help.
    shifty` likes this.
