  1. Sep 28, 2023 at 7:07 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Needed a stress relief project this evening so I took care of this p0155 code I've had since I bought the truck.
    Old and new
    The downstream sensor nuts were fawked. One came off without any hassle despite being so ugly. The other one was rounded off at some point prior to me. I used a hammer and a chisel to break it loose and then hammered on a 7/16 socket to get it the rest of the way off.
    Replaced the really ugly nut with something from the spare parts box. I'll get the proper hardware next time I'm ordering parts.
    A sensor wrench was 100% necessary. I originally rolled under the truck with just a standard 7/8 open end wrench, but due to how the sensor was clocked I couldn't get the wrench on given the limited access.
    All in all not so bad, Took about an hour start to finish.
  2. Sep 28, 2023 at 7:19 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    oscardog86 likes this.
  3. Sep 28, 2023 at 7:21 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    I mean if you really need to know now, I'll go check. But I'm already in my underwear. Almost bed time haha
  4. Sep 28, 2023 at 7:22 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  5. Sep 28, 2023 at 7:32 PM
    DJenerated
    Dija
    The Lone Star State
    I forgot what it said... Flow something... It was hot in the garage.
    Looks like this.
    I gave another one but the other style to a friend with a land cruiser. I don't think he's going to install it though. I might ask for it back when I see him next week lol
  6. Sep 28, 2023 at 7:34 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I need to kill a squeek coming from the leaf spring bushing. Front mount bushing drive side leaf spring. Just opening and closing driver side rear door is enough movement to make it squeek. Squeek squeek squeek. Lol. Can I spray some WD-40 or some silicone spray in there without taking it apart? Obviously taking it apart would be better so I can grease it or spray it real good but I'm lazy.
  7. Sep 28, 2023 at 7:36 PM
    Are you sure it's the bushing for the leaf pack, and not one of the individual leaves? There's supposed to be a shim between each leaf (toward the ends) to prevent squeaking. The bushing shouldn't be squeaking, it's just a tube of steel encased in rubber.
  8. Sep 28, 2023 at 7:36 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    txagg likes this.
  9. Sep 28, 2023 at 7:40 PM
    artsr2002
    'Yonder
    You right. I need to check those in fact I think I or
    You right. It could be the insulators. In fact pretty sure I already ordered replacements that I was going to install. I'll have to look for them but I'm pretty sure I did order them. Will replace those first and see if it gets rid of the squeek.
  10. Sep 28, 2023 at 7:42 PM
    artsr2002
    'Yonder
  11. Sep 28, 2023 at 8:19 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Had a shop that was recommended to me in Southern California do my timing belt today. The mechanic was really good at communicating with me, showing me things and explaining everything. He showed me my old parts and assured me that I had no leaks and everything looked good. 180,000 miles. Previous owner did it at 90,000 mi 10 years ago. So it was due.
    This mechanic has done a lot of belts on various cars, and he keeps a collection of the belts that come to him broken, damaging engines. As you can see, it doesn't matter how the belt actually looks. When you visually inspect it, they all look different. Some that look new still broke. He said keep up with your intervals and you'll be fine. Also, he said the Honda cars with this type of engine were more prone to breaking.
    He keeps these on display in his shop for customers to look at that are on the fans about changing their timing belt because it looks good
    Here is the shop information. Prices were reasonable
    https://maps.app.goo.gl/5AVSGoxcrbQCw7kx9
    I'm so happy now I could drive my new to me truck that I just bought two weeks ago with peace of mind
    dbittle, NUDRAT, bfunke and 7 others like this.
  12. Sep 28, 2023 at 8:26 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    hey now, thats not ideal. When one bag gets leaned on its gonna push that air into the other bag. Or you have a valve to close the crossover after filling?
  13. Sep 28, 2023 at 8:29 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yours look great. One of mine rusted away to nothing, the other looked like this.
    JakeJake[QUOTED] and txagg like this.
  14. Sep 29, 2023 at 12:35 AM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    My '04 has been marking it's territory for a couple of weeks. Bought the power steering return-side hose/pipe off AMZ for $30 ($107 @ O'Reilly) and swapped it out in about an hour. Sure am glad I had a 17mm crowsfoot wrench/socket for the rack end.
    txagg and KNABORES like this.
  15. Sep 29, 2023 at 6:07 AM
    artsr2002
    'Yonder
    @shifty` You were right. Just finished changing the two outer insulators near the end of the leaf springs. They weren't completely gone but had a glazed surface on them that was no doubt causing the squeek. I didn't change the two closer to the axle because the leaf clamp is there and it won't allow the leaves to spread very much. Even on the outer insulators I had to grind down the leg so I could fit them in the hole between the leaves. Dropped the ass end off after replacing all 4 and no more squeek. Noice!
    bmf4069, NUDRAT, shifty` and 2 others like this.
  16. Sep 29, 2023 at 6:13 AM
    Turns out he’s good for something besides growing giant airway cysts after all!
  17. Sep 29, 2023 at 6:14 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Dude not only is this great info, but its crazy cuz i live literally a mile from this shop! We must live really close to eachother! Haha
    shifty` and dirtnsmores[QUOTED] like this.
  18. Sep 29, 2023 at 6:17 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Dude, you have been on a roll lately!
  19. Sep 29, 2023 at 6:18 AM
    The older you get, the more you don’t give a shit. Turns out if you never did to start, doesn’t matter if you’re now an old fart.
    That ones free, my birthday is tomorrow.
    bmf4069, shifty`, DJenerated and 2 others like this.
  20. Sep 29, 2023 at 6:20 AM
    Going camping in the Ozarks this weekend riding mountain bikes. Had to borrow my BILs bike and put some new tires on it and adjust the derailleurs.
    bmf4069, NUDRAT, Voss and 7 others like this.
  21. Sep 29, 2023 at 6:22 AM
    On a less exciting note, the dreaded “click” no start is slowing returning. Time for more starter contacts it seems. Son went to leave for work in the FGT and it went click when he tried to start it about 4 times before the lucky turn fired it up.
    I will chronicle the replacement of said contacts and intake gaskets including my “no fuel rail or coolant line separation” kung fu technique, as it comes up frequently here.
    bmf4069, shifty`, txagg and 1 other person like this.
  22. Sep 29, 2023 at 6:54 AM
    How long ago did you replace those? I would think they should last as long as the original? I'm surprised they are going out again.
  23. Sep 29, 2023 at 6:59 AM
    DJenerated
    Dija
    The Lone Star State
    Happy early bday
  24. Sep 29, 2023 at 7:07 AM
    First replacement at 112k or so. It's been 156k and 16 years since then.
    DJenerated likes this.
  25. Sep 29, 2023 at 7:42 AM
    That's probably the earliest I've ever heard of a starter failing our our trucks. Mine is original at 190k as far as I know.
  26. Sep 29, 2023 at 8:13 AM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    No shutoff valves. I did think about this as well and figured I'd just see how it felt after a bit.
  27. Sep 29, 2023 at 8:13 AM
    image.jpg Getting wheels rebalanced 8 days since the last time
    bmf4069, 805Tundra, txagg and 2 others like this.
  28. Sep 29, 2023 at 8:44 AM
    I also feel like it’s mandatory for every tire shop to have a 1st gen RCLB
    bmf4069, Voss, dirtnsmores and 2 others like this.
  29. Sep 29, 2023 at 9:43 AM
    -Woodsman-
    -Woodsman- New Member
    NC
    05 SR5 DC Tundra 4WD
    That is good to know thanks for the feed back. I think I’m going to order one of those units.
  30. Sep 29, 2023 at 9:48 AM
